S14 KA24DE swap for my 510
DREWSDIME
I need some help for my S14 KA swap into my 510. I bought a engine and tranny from a 95 S14  but I did not get the harness. Im having trouble figuring out what I need , how do I tell if my engine is OBD1 or OBD2? I need to buy a harness ASAP but need to figure out which one to buy
  • Replies 16
only advantage would be the diagnostic codes from the ecu when something goes wrong. Otherwise it's more complex to install, parts usually cost more, and there is way less info out there on tuning the ecu.
ok looked into it and guess 96 also has obd 2, so with 96 97 98, there were about 15000 sold in the us. Also I think the throttle bodies had diff connectors between the two.
edit: looked and the TPS does differ between the two
