B.Teague Posted April 22, 2015 Report Share Posted April 22, 2015 I have an 82 Datsun king can that will crank and run fine for about 2 minutes. Then it will start to backfire and eventually stop. After that it will only run of the ignition is in the start position. If you let it go back to the run position it will die. I replaced one of the two coils. Anyone have any input on this please? Quote Link to comment
datzenmike Posted April 22, 2015 Report Share Posted April 22, 2015 First welcome to ratsun. Now stop replacing things. Here's why.... you may but something that doesn't work in and add to your running problems. Parts should only be replaced if you know them to be bad or not working. It's very likely that you now have three good working coils . Worse... the original coil is probably better qua;lity that the one you replaced it with. Did the engine run fine and just start running poorly lately? Or is this a 'new' truck and you have never had it working properly before? Quote Link to comment
B.Teague Posted April 22, 2015 Author Report Share Posted April 22, 2015 Sorry for being so vague about the history. The truck was bought new by my grandfather. I'm the 2nd owner. It ran great until I parked it a few years ago. Now I'm in resto mode and want to get it back into shape. The only reason I replaced the coil is because it had liquid coming out from around the top of it. Thanks for the welcome. Quote Link to comment
banzai510(hainz) Posted April 22, 2015 Report Share Posted April 22, 2015 i had this on my 510 where it would start but not run in the ON position. I wiggled back connectred of the key switch. I assume it was loose of corrosion. see if you have power to the coil with key ON. then ck fuse or fusable link. Im not a later truck expert. just best guess right now reseat connections as you said hassent been running so corrossion would be my best guess Quote Link to comment
datzenmike Posted April 22, 2015 Report Share Posted April 22, 2015 Better check both coils for power. If the exhaust side is out it's a fuse. The intake runs directly from the ignition switch. Quote Link to comment
B.Teague Posted April 22, 2015 Author Report Share Posted April 22, 2015 I will check these things today. Thank you and I'll keep you posted. Quote Link to comment
MicroMachinery Posted April 22, 2015 Report Share Posted April 22, 2015 Could it be fuel related instead of ignition? Quote Link to comment
kelowg Posted April 22, 2015 Report Share Posted April 22, 2015 Choke plate opening up fully when it starts acting up? Quote Link to comment
B.Teague Posted April 22, 2015 Author Report Share Posted April 22, 2015 At first I thought it was. But I've been keeping an eye on the sight glass and the fuel level stays around the right spot. I also can't keep it running long enough for the choke to release. I have though held the choke flap open and it still does the same thing. Quote Link to comment
ggzilla Posted April 22, 2015 Report Share Posted April 22, 2015 It is obviously a.problem with the ignition switch. Hainz had the same thing happen. Don't buy.a new switch, just unplug the back of it and clean the terminals. Quote Link to comment
MicroMachinery Posted April 22, 2015 Report Share Posted April 22, 2015 Wait, so you're saying that when it's cranking, it will "run", but as soon as you stop cranking, it doesn't? That doesn't sound like an "obvious" ignition switch problem. That sounds like it could be the starter keeping the engine cranking and firing on a minimal amount of fuel. If the primary jet is plugged, it will do exactly that. .. and if you don't believe that, it's happened to me. Quote Link to comment
ggzilla Posted April 22, 2015 Report Share Posted April 22, 2015 Obviously does not mean actually. It could be what happened to you. Or what happened to hainz ... and if you don't believe that, it's happened to me. You raise a good point. What does he mean by "run"? Maybe he meant actual running, not just firing over. Where if you hold the key partway between Run and Start like happened to me. Quote Link to comment
banzai510(hainz) Posted April 23, 2015 Report Share Posted April 23, 2015 That doesn't sound like an "obvious" ignition switch problem. means it has power to coil while holding key in START NO POWER to coil when KEY ON switch or blown fuse in power wire or bac connection. or wire fell off + side coil. Thats covers most of it. Quote Link to comment
