Silverdollar Posted April 21, 2015 Report Share Posted April 21, 2015 I have a 1985 2wd KC with a 31.5 tranny thats bad. Can anyone tell me what other Nissan I can search for to find the tranny..its been 8months so far and no luck 1 Quote Link to comment
flatcat19 Posted April 21, 2015 Report Share Posted April 21, 2015 720. 280zx. 620. 1 Quote Link to comment
ggzilla Posted April 21, 2015 Report Share Posted April 21, 2015 200SX, 280Z, 810 Almost easier to explain what doesn't work ... 1 Quote Link to comment
datsunaholic Posted April 21, 2015 Report Share Posted April 21, 2015 Well, if he wants a drop-in replacement it's a little harder than that. It's a NAPS-Z (unless it's a diesel) which means the only drop-in gearboxes are from a 81-86 720 or a 80-83 200SX. Otherwise, you have to take the gearbox apart and swap cases- which at that point you could just replace the broken bearings, because if it's worse than that usually the front case is shot too. And the front case is the critical part here. 2 Quote Link to comment
ggzilla Posted April 21, 2015 Report Share Posted April 21, 2015 Good point. Only need to swap the front case (bell housing). I've never seen a front case wear out. 1 Quote Link to comment
datzenmike Posted April 23, 2015 Report Share Posted April 23, 2015 The '80-'81 will have the exact same mid ratio gears as your '85. The '82-'83 has a wider ratio set similar to the 720 4x4. Not saying it won't work. Put your speedometer pinion sleeve into the new transmission to keep your speedo accurate. Use your current release bearing collar with any new transmission. 2 Quote Link to comment
jesusno2 Posted April 24, 2015 Report Share Posted April 24, 2015 Rebuilt it ???? not that hard to do 1 Quote Link to comment
