j_boy_619 Posted February 6, 2015 Report Share Posted February 6, 2015 Would these fit/work a 1975 b210? http://www.ebay.com/itm/Street-Edge-2-Universal-Extruded-Aluminum-Lowering-Block-Complete-Kit-/281542055339?pt=Motors_Car_Truck_Parts_Accessories&hash=item418d36d5ab&vxp=mtr The cheapest kit ive found so for is $80. so if these work that would be cool they are 2.20 inchs wide Quote Link to comment
datzenmike Posted February 6, 2015 Report Share Posted February 6, 2015 $50 to ship? Rubbish!!! Just buy the U bolts at the hardware store and two 4" long sections of 2"X2" steel square channel tubing. Obviously get 1/4" thick for strength. Probably $10 including the cutting. Quote Link to comment
j_boy_619 Posted February 6, 2015 Author Report Share Posted February 6, 2015 No i mean I found a set for 60 but 20 for shipping. Then I found these ones so I was hoping they would fit cuz theyre cheaper Quote Link to comment
j_boy_619 Posted February 6, 2015 Author Report Share Posted February 6, 2015 I just want to know if this set will fit. I checked the 1200 site and they said the B210s axle was a 2.20 so i was thinking just maybe these will fit Quote Link to comment
Ranman72 Posted February 6, 2015 Report Share Posted February 6, 2015 check the u bolt spacing to make sure it fits also the block has to fit between your u bolt plate so check that too Width: 2.20" Length: 4.85" U Bolt Measurements Inner Width: 3.125" Overall Length: 9" Thread Length: 3.8 Quote Link to comment
j_boy_619 Posted February 6, 2015 Author Report Share Posted February 6, 2015 check the u bolt spacing to make sure it fits also the block has to fit between your u bolt plate so check that too Width: 2.20" Length: 4.85" U Bolt Measurements Inner Width: 3.125" Overall Length: 9" Thread Length: 3.8 k, i'll check this out tomorrow morning Quote Link to comment
charolastra Posted February 6, 2015 Report Share Posted February 6, 2015 Blocks or rearching leafs? What is the best option? If I want to lower my car 3" Quote Link to comment
datzenmike Posted February 6, 2015 Report Share Posted February 6, 2015 Blocks are faster cheaper and easier than re-arching. In either case the spring should be stiffened to reduce suspension travel and the resulting bottoming out on the pavement. If adding blocks a smaller 'load leveler' coil can be clamped to the shock. If re arching the springs have an extra leaf added. I've also seen the front and rear of a leaf spring bent downwards. Quote Link to comment
j_boy_619 Posted February 6, 2015 Author Report Share Posted February 6, 2015 doesnt look like my option was going to work Quote Link to comment
j_boy_619 Posted February 6, 2015 Author Report Share Posted February 6, 2015 fudge. having no luck finding a set. Might have to start looking into making my own now Quote Link to comment
SlammedSunny Posted February 6, 2015 Report Share Posted February 6, 2015 They are very simple to make, 2x2 solid aluminum roughly 4-5/8" long (thats from memory and could be wrong), drill a hole straight through the center, tap it on one side and install a Socket head cap screw as a centering pin; Done. As for the U bolts, i took my stock ones down to a local 4x4 shop and asked them to make me a set of 4 with the same dimensions but 2" longer. All said and done i made my own 2" blocks for under $40 in one day. If you want exact measurements let me know and ill grab some pictures and measure them for you. Quote Link to comment
charolastra Posted February 8, 2015 Report Share Posted February 8, 2015 Thanks datzenmike, you are the best. Quote Link to comment
Sierra Posted February 26, 2015 Report Share Posted February 26, 2015 Any updates on the lowering blocks? Quote Link to comment
j_boy_619 Posted February 26, 2015 Author Report Share Posted February 26, 2015 2 Quote Link to comment
j_boy_619 Posted February 26, 2015 Author Report Share Posted February 26, 2015 Front: 1200 strut top swap + 2 coils cut Rear: 2 Inch aluminum blocks w/ custom u-bolts 1 Quote Link to comment
thatdirtykid Posted February 28, 2015 Report Share Posted February 28, 2015 Jboy what bumpers are those? I like the stance too, how does the front fit? any rub, what tire size? Quote Link to comment
j_boy_619 Posted February 28, 2015 Author Report Share Posted February 28, 2015 front is from a toyota corona i found at the junkyard and the rears were the bumperettes from some old volvo or something. like 1960s as for the tires, they are 185/60/14. They rubbed a little so i just pulled out the fender a bit. It rides nice and turns sooo much better, but on a shit road you feel it :hyper: Quote Link to comment
thatdirtykid Posted February 28, 2015 Report Share Posted February 28, 2015 Sweet, good to hear I like the tire size and fit. I also am running 185/60s but have not gone lower yet. I bet a corona bumper is easier to find at a decent price than JDM Sunny bumpers. Quote Link to comment
charolastra Posted March 12, 2015 Report Share Posted March 12, 2015 can i see the front of the car? can you post a picture please? looks very nice :thumbup: Quote Link to comment
