rbastedo Posted January 6, 2015 Report Share Posted January 6, 2015 I see the last I posted about my A15 motor rebuild was Oct. 1st. My new pistons are pressed onto the rods and they're sitting in a box. I've got rings and all the tools I need to reassemble, but before getting to it I'm wondering if there's any great Bang for the Buck upgrades I could do? It's got a stock cam, would getting it reground be beneficial? I want to use the car for driving, not racing but am not opposed to a bit of extra power. Is there a better then original oil pump or anything else I should do before buttoning it up? Thanks! Quote Link to comment
Doctor510 Posted January 6, 2015 Report Share Posted January 6, 2015 Delta Camshaft John Bodwell 2366 Tacoma AVE S.Tacoma, WA 98402 Phone: (800) 562-5500 Get a regrind, call them a TW John. Tell him that Dick at CHAOS Racing in Arizona asked you to call. Quote Link to comment
rbastedo Posted January 6, 2015 Author Report Share Posted January 6, 2015 Tacoma - just around the corner from me. Thanks! Any suggestions on what to ask to be done to my cam? I've never had one done before. Quote Link to comment
Stoffregen Motorsports Posted January 7, 2015 Report Share Posted January 7, 2015 If they have any knowledge of Datsuns then they should be able to steer you in the right direction based on what you want. Header or no header, stock intake and carb or Weber DGV, daily driver, sit in traffic a lot, etc. Those are all things you are going to want to tell them. If they don't have any suggestions, then maybe someone here has actual cam specs for a cam they like. Quote Link to comment
rbastedo Posted January 7, 2015 Author Report Share Posted January 7, 2015 Thank you! It has the H89 head, dual British HIF4 SU carbs. At this point installing a header is an option, I haven't looked into it at all but I think it would at least look cool in there and would maybe increase performance a little? Anyone got suggestions for a good but not too expensive exhaust header? It won't be sitting in traffic, I "drive it like I stole it" most of the time. I may have been known to do stuff like: seeing a very straight and well paved piece of empty highway ahead I may have given in to temptation a couple times. I have driven this car at Road America, Elkhart Lake Wisconsin, (actually on the track for an event) in a "spirited" way. So I don't want anything that will make it too uncomfortable on a road trip but I'd like it to have a little more punch and maybe some longer legs under it. One thing to consider is that currently the exhaust exits very close to the drivers footwell, I have insulated the heck out of this area but it still gets pretty warm there. The car has a 3.73:1 rear end and the 60 series dogleg 5 speed. Quote Link to comment
rbastedo Posted January 7, 2015 Author Report Share Posted January 7, 2015 Here is my ultimate plan for the car, it's called an Arkley SS. I have the glass body kit and (no shit) gold plated suspension parts from the dearly departed ex USA importer of the Arkley. I'll buff up all the suspension parts before installing and probably clear coat it all so as to make it easy to keep clean. The guy was nuts for having stuff plated and this was going to be his personal car before he passed, I bought it from the widow. (this isn't my car, just an example that shows what I hope to do with mine) Thank you! It has the H89 head, dual British HIF4 SU carbs. At this point installing a header is an option, I haven't looked into it at all but I think it would at least look cool in there and would maybe increase performance a little? Anyone got suggestions for a good but not too expensive exhaust header? It won't be sitting in traffic, I "drive it like I stole it" most of the time. I may have been known to do stuff like: seeing a very straight and well paved piece of empty highway ahead I may have given in to temptation a couple times. I have driven this car at Road America, Elkhart Lake Wisconsin, (actually on the track for an event) in a "spirited" way. So I don't want anything that will make it too uncomfortable on a road trip but I'd like it to have a little more punch and maybe some longer legs under it. One thing to consider is that currently the exhaust exits very close to the drivers footwell, I have insulated the heck out of this area but it still gets pretty warm there. The car has a 3.73:1 rear end and the 60 series dogleg 5 speed. Quote Link to comment
rbastedo Posted January 10, 2015 Author Report Share Posted January 10, 2015 Right now the stock exhaust runs within 1/16 - 1/8 inch from the drivers foot well. If I can get a header in there maybe I can get it to fit with a bit more space between the exhaust and foot well, which would decrease operating temperature inside near the accelerator pedal and that would make longer drives a lot more comfortable. I've insulated the area but it still gets very warm. I am open to other ideas, is there a header for another engine that's close, could be cut and re-welded or heated and bent / adjusted? I expect to have to do something to anything I get as this application isn't "standard". Quote Link to comment
datzenmike Posted January 10, 2015 Report Share Posted January 10, 2015 The stock exhaust manifold or the down pipe? If the down pipe, have one made that has more clearance. Maybe this has been replaced with an off the shelf muffler place part that is just poorly made and fitted? Quote Link to comment
rbastedo Posted January 10, 2015 Author Report Share Posted January 10, 2015 Geez trust someone with a Walter White tagline to cut to the chase and just get to the point. That makes so much sense I can't believe I didn't see it myself. Thanks Mike! Quote Link to comment
