sdsurf Posted September 22, 2008 Report Share Posted September 22, 2008 Where is the location for the ground on the engine? 521/L16 Quote Link to comment
datsunaholic Posted September 22, 2008 Report Share Posted September 22, 2008 Stock, the negative battery cable went to a bolt on the side of the block below and behind the fuel pump. It is best, however, to add a few particularly between the head and body. Quote Link to comment
sdsurf Posted September 22, 2008 Author Report Share Posted September 22, 2008 Stock, the negative battery cable went to a bolt on the side of the block below and behind the fuel pump. It is best, however, to add a few particularly between the head and body. Got any pics? Quote Link to comment
datsunaholic Posted September 23, 2008 Report Share Posted September 23, 2008 No, I don't. Heck, maybe the L16 only had the point on the head (where the lifting eye goes). I'm too used to where the L20B ground bolt goes. I've used both. And I don't have a stock 521 to look anymore. Quote Link to comment
hang_510 Posted September 23, 2008 Report Share Posted September 23, 2008 the L16 only had the point on the head (where the lifting eye goes). I'm too used to where the L20B ground bolt goes. I've used both. the block is a better spot than the (AL)head, the block-head combo :lol: would be easy to do. Quote Link to comment
dat521gatherer Posted September 26, 2008 Report Share Posted September 26, 2008 i would love to see a factory pic of this answer myself. iv'e always used the fuel pump stud for the lifting eye. Quote Link to comment
dat521gatherer Posted September 27, 2008 Report Share Posted September 27, 2008 looking at a photo in the owners manual the battery ground goes to the lifting eye next to the fuel pump. Quote Link to comment
mklotz70 Posted September 27, 2008 Report Share Posted September 27, 2008 pg 220 of the factory manual(avail on the tech page of http://www.olddatsuns.com) only shows the battery ground cable going to the alternator body. That would be stock. Running the ground to the block helps with the return side from the starter, which carries more current than all the other systems combined. Grounding the head helps with the return circuit from the spark plugs. I highly recommend running a ground from the eng to the body. The only stock ground between the two that I know of is a 10ga wire between the bellhousing(near starter) to the frame. Since all the lights/wipers/radio/wiper...all ground to the body, an additional ground from the bat to the body is a good idea. You can either run it from the eng to the body, or directly from the bat. Anyone wanting the strongest ignition should run a dedicated ground to the distributor body....points or EI. Quote Link to comment
datzenmike Posted September 27, 2008 Report Share Posted September 27, 2008 Mike's right on this. I had a catastrophic short from the POS to the body. The only path to the engine block was down the throttle cable... which got HOT! the plastic melted and hardened around it. No throttle at 1:30 in the morning with 15 miles to get home. On some 720s the NEG cable has a lug on it about a foot from the battery that bolts to the inner sheet metal fender then on to the intake manifold. Quote Link to comment
dat521gatherer Posted September 28, 2008 Report Share Posted September 28, 2008 yeah that owners manual was a guess. i love to stroll through the 521 service manual just to look at the pics. on that diagram it does show the ground cable going to the alt but i cant tell that it's connected to the top or bottom mount. maybe i'll stroll through the book some more and try to find an actual pic.. best book to have if you have a 521. Quote Link to comment
dat521gatherer Posted September 28, 2008 Report Share Posted September 28, 2008 sycloned916's alternator thread has a great pic of the stock negative battery cable mounted to the front of the top alt bracket bolt. its a j13 engine. Quote Link to comment
sdsurf Posted September 29, 2008 Author Report Share Posted September 29, 2008 ok... Should I ground the block (engine) to the fire wall? Negative battery to alt mount? anything else? Quote Link to comment
dat521gatherer Posted September 29, 2008 Report Share Posted September 29, 2008 take the ground wires off your voltage regulator mounting screw/bolt and clean/sand/dremel the surfaces til they shine. actually take the whole volt reg off and clean the back mounting surfaces and the surrounding bolt holes where they go. one of the best preventive maintenance you can do. Quote Link to comment
