Elkie Posted December 1, 2014 Report Share Posted December 1, 2014 I have a 77 620 I am swapping over to an 80's subaru alt. Looking at the wiring the PO spliced a wire from the ballast resistor into the white/blue wire coming off the regulator, which is eliminated when removing the external regulator. I see that the white/blue wire runs to the fuse panel from the 76 wiring diagram. What was the purpose of the wire originally, and does anyone have a link to a working good quality 77 wiring diagram. Quote Link to comment
banzai510(hainz) Posted December 2, 2014 Report Share Posted December 2, 2014 white/blk stripe SHORT with white / red stripe then yellow SHORT with white. this is a datsun 510 but should be the same on the trucks i dont know white blue stripe but alot of people hook to the Ballast as its a switchable 12volt. you sure its not going to the carb choke or something. Sounds kinda hoky to jump a wire from drivers side to the pass side to get 12volts Quote Link to comment
Elkie Posted December 2, 2014 Author Report Share Posted December 2, 2014 They swapped in a manual choke weber, I can't tell whether they spliced it in to send power to the ballast, or to get power to the white blue wire(which seems less likely). Quote Link to comment
banzai510(hainz) Posted December 2, 2014 Report Share Posted December 2, 2014 datzenmike knows more on this and he will chime in. The ballasst resisitor the blk/ wht wire is usually the Switchable POWER comming from fuse box. If NO power with key ON from this wire then that needs to be fixed. also if you d a IR swap the electric choke relay needs to be disconnected as it will drain the battery Quote Link to comment
datzenmike Posted December 2, 2014 Report Share Posted December 2, 2014 There should be two wires to the old carb. A Red for the idle cut... only on with the ignition. A Blue wire to the choke heater (from the choke relay)... only on when running. The Red wire is a good source for 12 volts when starting and running and could be fed to the points and the ballast resister if needed. Hainz is totally correct about the choke relay. If not disconnected the small coil inside is energized constantly and will slowly drain your battery over a weekend.. Quote Link to comment
Elkie Posted December 2, 2014 Author Report Share Posted December 2, 2014 I removed the wire from the ballast and was getting ~11v still. Thanks for the heads up on the relay, its now unplugged. Gonna hijack my own thread and go ahead and ask what this is. Quote Link to comment
difrangia Posted December 3, 2014 Report Share Posted December 3, 2014 If your pickup had dealer installed air-cond at one time, it could possibly be the electric valve that sends vacumn to the fast Idle contraption on the carb. Steve Quote Link to comment
Elkie Posted December 3, 2014 Author Report Share Posted December 3, 2014 ah that makes sense, I'm pretty sure it had factory a/c. It does have what appears to be the remains of a vacuum hose on the right side. Quote Link to comment
difrangia Posted December 3, 2014 Report Share Posted December 3, 2014 Mine had dealer add air and I've thought of putting a switch on the valve and re-plumbing it to get fast idle on cold mornings but I;m changing to Weber carb in the not-so-distant future. Quote Link to comment
banzai510(hainz) Posted December 3, 2014 Report Share Posted December 3, 2014 looks hoky to me. That doesn't look like a Datsun wire to me. At first I thought it was a Ford starter seliniod. But you say there is a vacuum line to it.(u sure its a vaccum line?Not heat shrienk) Quote Link to comment
Elkie Posted December 3, 2014 Author Report Share Posted December 3, 2014 that orangish wire is the one i was talking about earlier that runs to the ballast. I was thinking about adding a/c back in, would have to figure out a way to bump the idle on a weber when ac is running Quote Link to comment
banzai510(hainz) Posted December 3, 2014 Report Share Posted December 3, 2014 that orange wire even hooked up to the selinoid thing or just got tie wrapped to it and goes to the volt reg like you said earlier. If yes then thats a bypass hoky set up. take some good clear photos of where its hooked up at both sides. Quote Link to comment
Elkie Posted December 4, 2014 Author Report Share Posted December 4, 2014 Just zip tied to stuff along the way. Quote Link to comment
banzai510(hainz) Posted December 4, 2014 Report Share Posted December 4, 2014 OK now twhat color is that hooked up to an where those that wire go to. what happens if diisconnected? Quote Link to comment
Elkie Posted December 4, 2014 Author Report Share Posted December 4, 2014 Spliced to the white/blue wire. I can't find a good 77 wiring diagram, but looking at a 76 the wire starts at the regulator and runs to the fuse panel. So far I can' tell that it does anything after unhooking it. Confused as to why this was done. Quote Link to comment
banzai510(hainz) Posted December 4, 2014 Report Share Posted December 4, 2014 make sure our charging and its regulating correctly. My first thought maybe the alternator wasnt getting the 12volts for the alternator winding will have power so your alt camn make output but im not familiar with the 620 and the wht blu wire. my 521 truck I had no output on my alt. I swapped another alt and a volt reg only to find out I had no 12volt at the T connector to get 12volts on the windings. I reseat the instrumen panel harness in back and I guess it passed 12volts thru there via the IGN lamp light. then it was good. Quote Link to comment
Elkie Posted December 4, 2014 Author Report Share Posted December 4, 2014 Swapped the alternator out for a 60 amp IR alternator, tested while running was about ~14v, so it seems to be running fine w/o it hooked up. I didn't do any testing before I pulled the old one so maybe it served some purpose like you mentioned for the original set up. Quote Link to comment
