biker16ben Posted September 5, 2014 Report Share Posted September 5, 2014 Need a 1977 620 L20b timming indicator tab.No longer available by order.Looked threw classfieds,no luck.Thanks Ben Quote Link to comment
banzai510(hainz) Posted September 5, 2014 Report Share Posted September 5, 2014 there are soem left hanfd or right hand onnes. I dont know if they are really the same. as I seen then on both sides or the timming cover. so I gues you got to know where your TDC on crank is. what side is it on? Quote Link to comment
5t341tH Posted September 6, 2014 Report Share Posted September 6, 2014 I was able to buy mine brand new from dealer. Cost me about 4-5 bucks PN: 13502-w0400 Slightly different than L20 one but works fine. compared to this http://community.ratsun.net/topic/7103-setting-timing-on-the-l20b/?do=findComment&comment=101653 Quote Link to comment
biker16ben Posted September 6, 2014 Author Report Share Posted September 6, 2014 Im thinking its the left one and mounts on the driver side.Does this one mount on the water pump with one bolt hole and the other slides over the water pump dowel pin? I'll pull #1 plug and see where the pully mark lines up.I'll be back! lol Quote Link to comment
datzenmike Posted September 6, 2014 Report Share Posted September 6, 2014 All L20B I've seen fit the passenger side near the alternator and fit on the timing chain cover bolts. It's the small tab above my finger. It's edge on but you can see the saw tooth shadow. Quote Link to comment
biker16ben Posted September 6, 2014 Author Report Share Posted September 6, 2014 Your right , I found it.It was covered with grease and way down there.Im a chevy guy and this is my first Datsun.Thanks for the reply bro. Quote Link to comment
datzenmike Posted September 6, 2014 Report Share Posted September 6, 2014 It's why we're here. No problem 1 Quote Link to comment
