Eomund Posted August 13, 2014 Report Share Posted August 13, 2014 Most posting a question about my distributor. This is on my L20b. I'm still running the points distributor. Specifically, getting the squeel from the vacuum advance. I noticed it happened when the vacuum hose had fallen off. I put it back on and the noise slowly went away. Just curious if anyone has experienced this? And what might be the cause, mostly if I need to replace something before something gets damaged. Any input would be fantastic. Thanks in advance. Quote Link to comment
datzenmike Posted August 13, 2014 Report Share Posted August 13, 2014 Hose have a split in it? Take cap off and suck on the carb end. The rotor should turn clockwise about an inch and hold till you release it. If it won't hols and returns either the vacuum diaphragm inside or the hose has a leak. Quote Link to comment
Eomund Posted August 13, 2014 Author Report Share Posted August 13, 2014 I know the hose doesn't have a leak, it's only like 6 months old. It wouldn't surprise me even a little if the diaphragm is shot. I'll give the vacuum test a shot when I get home tonight. I have a CDI one ready to go on if this bugger is dying. I just need to do a little research on how to install it first. Quote Link to comment
banzai510(hainz) Posted August 13, 2014 Report Share Posted August 13, 2014 squeel when hose OFF???????? then it would come from the carb then right? If hose is off then the diaprahm isnt going to be used anyways. then its a mechanical noise not a air noise. Quote Link to comment
Eomund Posted August 13, 2014 Author Report Share Posted August 13, 2014 Yes, it's a mechanical noise for sure. It's specifically coming from the distributor, loudest directly from the Diaphragm. I used my stethoscope on it to get exactly where the sound was coming from. While making the noise, the diaphragm was vibrating too. The noise going away when I put the hose back on very well might have been either a coincidence, or maybe the hose is just absorbing the extra vibration enough to kill the sound. Or a possibility the hole that the hose covers is where the squealing is being amplified some how, and the hose is diverting the noise some how. I know these are all possibilities of why the noise started, but what in the Dizzy can make a squealing / whining noise? Is it something that can be fixed (relatively easily if possible), or should I just bin the thing and find out how to install the non points one I have? P.S. If anyone links me to a walk through on swapping to a pointless distributor, I'll owe you one :) Quote Link to comment
dr.feltersnatch Posted August 13, 2014 Report Share Posted August 13, 2014 by pointless do you mean matchbox? Quote Link to comment
dr.feltersnatch Posted August 13, 2014 Report Share Posted August 13, 2014 http://community.ratsun.net/topic/50151-electronic-ignition-conversion-factory-datsun-matchbox/ Quote Link to comment
Eomund Posted August 16, 2014 Author Report Share Posted August 16, 2014 Well, just swapped out the distributor. It was easier than I thought it would be. :) Quote Link to comment
