Scgreen620 Posted August 5, 2014 Report Share Posted August 5, 2014 Hey 620 owners is there any one out here that has done the aluminum radiator swap and fan ?Where did you guys buy the radiators and what size did you guys use for fans ? Thanks Quote Link to comment
flatcat19 Posted August 5, 2014 Report Share Posted August 5, 2014 Horrible thread title. Totally misleading. I. Am. So. Mad. Right. About. Now. 2 Quote Link to comment
datzenmike Posted August 5, 2014 Report Share Posted August 5, 2014 Fixed the title so now everyone who doesn't give a shit doesn't have to open it to find that out. You know what you want, but not everyone else does. A sensible title attracts those interested. 1 Quote Link to comment
flatcat19 Posted August 5, 2014 Report Share Posted August 5, 2014 Thanks for that, Mike. I was so close to kicking a kitten over that. Quote Link to comment
Scgreen620 Posted August 6, 2014 Author Report Share Posted August 6, 2014 Mike is there a way I can move it to the truck thread? Quote Link to comment
]2eDeYe Posted August 6, 2014 Report Share Posted August 6, 2014 Moved it to the 620 section. :) Quote Link to comment
Scgreen620 Posted August 9, 2014 Author Report Share Posted August 9, 2014 Thank you I hope I get help ... Quote Link to comment
datzenmike Posted August 9, 2014 Report Share Posted August 9, 2014 Thank you I hope I get help ... Funny on at least two levels. 1 Quote Link to comment
flatcat19 Posted August 10, 2014 Report Share Posted August 10, 2014 Buy the aluminum radiator from eBay and use your stock fan with the original shroud. Easy. Quote Link to comment
datzenmike Posted August 10, 2014 Report Share Posted August 10, 2014 The above... An electric fan has advantages though. It is only on if needed and if the vehicle is going over 30MPH it isn't needed at all as air will pass through the rad just from forward motion. It's possible to start the engine and drive 250 miles and never have it come on at all. You will need it in stop and go traffic or prolonged idling. The fans must be on a thermal switch. A driver operated switch is foolish unless you constantly watch the gauge and then remember to turn it off. If you plan that, you might as well just leave the mechanical fan on there. Electric fans that rarely turn on save way more than a mechanical one that is on all the time. Quieter also. Quote Link to comment
Scgreen620 Posted August 12, 2014 Author Report Share Posted August 12, 2014 I heard it gains hp is that true? Quote Link to comment
datzenmike Posted August 12, 2014 Report Share Posted August 12, 2014 A hp maybe two, maybe, but there may be mileage gains as this load on the engine is eliminated with an electric fan that rarely comes on. Quote Link to comment
Jonatsun Posted August 12, 2014 Report Share Posted August 12, 2014 Hey guys check this out for a good 620 forum http://community.ratsun.net/topic/63631-fuel-nipple-inlet-help-on-hitachi-dch-340/?do=findComment&comment=1129542 Sorry and thank you Quote Link to comment
