datson4life Posted June 25, 2014 Report Share Posted June 25, 2014 Ive had that issue where when my idle is too low, the voltage drops Quote Link to comment
banzai510(hainz) Posted June 26, 2014 Report Share Posted June 26, 2014 with lights on it might be near 12voolts. sound like the alt works key is if heater and lots of other stuff on. Maybe it just needs another alt or bet cked or new batt cables or cleaned Quote Link to comment
aintnobiscuit Posted July 1, 2014 Author Report Share Posted July 1, 2014 Lights killing the engine - appears to be that the idle is too low Gas & temp gauge being all crazy - Someone tried to do the voltage regulator swap I did a write up on but there is a burnt up wire on the PCB, this is causing my gauge issues Going to fix both of those issues and heat shrink some wires. I think those two things will solve my electrical problems. Then I just need to fix the oil leak, order a coolant overflow bottle, rear view mirror and cabin light bulb. Quote Link to comment
DanielC Posted July 1, 2014 Report Share Posted July 1, 2014 A 521 did not have a coolant overflow bottle, but you can add one. I just have a pop can, in front of the alternator, next to the radiator, held by the lower radiator hose. The inside rear view mirror uses a 1/2 inch ball mount. This is pretty common. I have found a rear view mirror from a Mazda B2000 works really well, and I think it was made bt the same company that made the Datsun mirror. Maybe a little investigation, and time on a junkyard, you could find a mirror with a "night" lever to reduce glare from cars behind you. Quote Link to comment
aintnobiscuit Posted July 1, 2014 Author Report Share Posted July 1, 2014 Oh really? ha ha ha... i started looking online for coolant overflow bottles but was having trouble finding one so that explains it. I saw several different oem looking solutions so i'll probably swipe one from the junkyard. Pretty sure it's half off entrance fees during holiday weekends - 4th of July is this weekend.... w00t! Quote Link to comment
