Dime Dave Posted June 4, 2014 Report Share Posted June 4, 2014 I know, some guys are going to crap all over the idea... but has anyone removed the vent window and converted their 521 to one piece door glass? Quote Link to comment
mklotz70 Posted June 4, 2014 Report Share Posted June 4, 2014 Hi Dave, I know of this one... http://community.ratsun.net/topic/36324-69-521-toys-toys-toys/page-8 Not finished, but should give you a good view into the door and some of the grief. Quote Link to comment
mrbigtanker Posted June 4, 2014 Report Share Posted June 4, 2014 You making something because i have thought of this idea for 7 years now,and was just going to pursue it myself. They do them for bugs old chevy's you name it. MOre custom then stock but i like the clean look and more room to hang my little arms out the window when driving.lol Quote Link to comment
Dime Dave Posted June 5, 2014 Author Report Share Posted June 5, 2014 Mike, Thanks for the link. mrbigtanker, not planned as a FutoFab product at this point (or even a personal project). It was more a fact finding mission for options to deal with some less than perfect vent windows.. The pictures Wayno posted in the thread Mike linked to above are very helpful. Not having a spare door to cut open it looks like the window frame that forms the track above continues down to the bottom of the door at the front. If it runs parallel to the rear track it could be used to guide at the forward edge of the glass. It could also serve as a place to run a spring loaded roller that would help keep the glass up against the rear track. A vertical electric lift looks like it would be the easiest way out, but I like the hand crank aspect. Harvesting the regulator/lift system from a 510 with its "X" mechanism and two point glass support might be a good option as well. I have 510 doors that can be used to exploration/harvesting when I get to that point. Quote Link to comment
wayno Posted June 6, 2014 Report Share Posted June 6, 2014 I put that front track in there, I cannot recall now where it came from though, it might have been the lower wingwindow frame assembly from that Mazda frame assembly I bought trying to make a Mazda wingwindow gasket work in the 320 wingwindow frame. That door was one that I used the outer sheet metal for my 521 kingcab as a filler, that door is long gone now, I used the rest of the window channel for the rear windows in my 520 project. Mike, Thanks for the link. mrbigtanker, not planned as a FutoFab product at this point (or even a personal project). It was more a fact finding mission for options to deal with some less than perfect vent windows.. The pictures Wayno posted in the thread Mike linked to above are very helpful. Not having a spare door to cut open it looks like the window frame that forms the track above continues down to the bottom of the door at the front. If it runs parallel to the rear track it could be used to guide at the forward edge of the glass. It could also serve as a place to run a spring loaded roller that would help keep the glass up against the rear track. A vertical electric lift looks like it would be the easiest way out, but I like the hand crank aspect. Harvesting the regulator/lift system from a 510 with its "X" mechanism and two point glass support might be a good option as well. I have 510 doors that can be used to exploration/harvesting when I get to that point. I would agree that electric is likely the easiest way to go with a one piece window Quote Link to comment
