bryant2482 Posted June 4, 2014 Report Share Posted June 4, 2014 ok i like my ride being low but i also want it to be ridgid. im pretty sure by now my stock rear leafs are worn, especailly over the years of constant heavy hauling, so ive been thinking about switching over to the belltech drop leaf springs. has anyone here gone with these and if so are the worth the money? Quote Link to comment
wayno Posted June 4, 2014 Report Share Posted June 4, 2014 You have a link to these drop leafs? 720 4X4 leafs will give you a 1 1/2 inch drop, and they are firmer I believe. Quote Link to comment
thisismatt Posted June 4, 2014 Report Share Posted June 4, 2014 You could try 720 4x4 leafs which will provide a ~1.5" drop and be more stiff (442lbs vs 310lbs per inch). This guy supposedly got the belltechs: http://community.ratsun.net/topic/61527-leaf-springs/ Quote Link to comment
bryant2482 Posted June 4, 2014 Author Report Share Posted June 4, 2014 i found some individually sold on ebay. hmm ok 4x4 leafs huh, ill take your word for it! Quote Link to comment
bryant2482 Posted June 4, 2014 Author Report Share Posted June 4, 2014 do you guys have any links to 4x4 leafs? Quote Link to comment
bryant2482 Posted June 4, 2014 Author Report Share Posted June 4, 2014 dayum! i have no luck in vegas salvage yards. usually theres nothing left Quote Link to comment
wayno Posted June 4, 2014 Report Share Posted June 4, 2014 Finding 4X4 leafs in Las Vegas might take some waiting, it seems that you don't have a lot of Datsuns there, do you ever travel to places that have more Datsuns around, you could go to a wrecking yard in one of them places. Eagle Adam has been known to sell 4X4 leafs fairly regular, the trouble is that by the time you buy the very heavy leafs and get them shipped to your location, it might be cheaper to buy the BellTech drop leafs, it depends on how much they are, I suspect you could get a set of 4X4 720 leafs shipped to you for somewhere around $200.00 or less, a $100.00 for the leafs, and another $100.00 for shipping, but that doesn't leave much for profit on the one pulling the parts. Canby is happening the weekend after next, maybe someone is driving threw Nevada on there way home from Canby and can pick up a set while there. Personally I would wait for a 4X4 to show up in a wrecking yard near you, it might take a while, but one is bound to eventually show up. Quote Link to comment
bryant2482 Posted June 4, 2014 Author Report Share Posted June 4, 2014 honestly i never have seen a 4x4 in the wrecking yard. its always 2wd Quote Link to comment
wayno Posted June 4, 2014 Report Share Posted June 4, 2014 honestly i never have seen a 4x4 in the wrecking yard. its always 2wd 2wd leafs are different, you can tell if they are 4X4 leafs by the eye on the end, it's centered. Quote Link to comment
Omelet720 Posted June 4, 2014 Report Share Posted June 4, 2014 The 4x4 leaves I picked up at the sunrise PnP had two bolt-ons on either side of the helper leaf. Wayno do you know if the leaves on the heavy-duty 720 had a higher spring rate than the standard or 4x4? I can't find any info on what made it heavy-duty. Quote Link to comment
wayno Posted June 5, 2014 Report Share Posted June 5, 2014 The 4x4 leaves I picked up at the sunrise PnP had two bolt-ons on either side of the helper leaf. Wayno do you know if the leaves on the heavy-duty 720 had a higher spring rate than the standard or 4x4? I can't find any info on what made it heavy-duty. I believe the lower leaf is the one ton leaf pack, I found it on a late 720 dually as I recall. Quote Link to comment
Omelet720 Posted June 7, 2014 Report Share Posted June 7, 2014 I don't have the dually. I have an 84 long bed, but it had a very standard looking 2 leaf pack with a long and short overload. The 4x4 pack I picked up is the same, but it has a 3 inch long pack on the bottom of each overload spring. Quote Link to comment
