bonvo Posted September 10, 2008 Report Share Posted September 10, 2008 ok i have a few questions what are likly reasons that tails and side markers dont work but headlights do ? what are likly places for the harness to have issues? Quote Link to comment
moparvwfreak Posted September 10, 2008 Report Share Posted September 10, 2008 check the fuse for them. also could be a bad switch. Quote Link to comment
ppeters914 Posted September 10, 2008 Report Share Posted September 10, 2008 These harnesses are over 30 years old. The whole thing is a likely weakness. :lol: Seriously, first clean all the connections and grounds. Amazing how many electrical issues are resolved that way. If still not working, start checking voltages until you find the break. Quote Link to comment
bonvo Posted September 10, 2008 Author Report Share Posted September 10, 2008 i figured it out the h4 headlights i have use a different prong for ground then the stocker does so the power is going to ground hence fucking me all up problem solved rewire the h4s later for now throw sealed beams in it Quote Link to comment
zerow Posted September 10, 2008 Report Share Posted September 10, 2008 Do the sidemarkers and tails light up when the switch is in the position for headlights?? If not, then the switch is bad, but if they do light up, then (a PITA procedure...) remove the switch and check for continuity over the Green/Blue and Green/White wires. No continuity in position one, switch is at fault. Are your dash lights turning on? They are also part of position one. Quote Link to comment
hang_510 Posted September 10, 2008 Report Share Posted September 10, 2008 are the tails and HL fused on different circuits, like a 510? i 2nd and 3rd the bad connections. Quote Link to comment
bonvo Posted September 10, 2008 Author Report Share Posted September 10, 2008 i disconnected my headlights at the fuses and it worked fine then i disconnected them at the lights and connected the fuses and they work so its the headlights Quote Link to comment
moparvwfreak Posted September 10, 2008 Report Share Posted September 10, 2008 cool. at least ya figured out what was up. also that link i sent you should help ya out alot when you go to rewire them. Quote Link to comment
