edekalil Posted May 26, 2014 Report Share Posted May 26, 2014 What is the average RPM a stock 1600 in a 510 with stock trans at 70 mph runs? Quote Link to comment
DanielC Posted May 26, 2014 Report Share Posted May 26, 2014 A lot. This ain't your grandfathers V8. I do not have a 510. I have a 521, with a 4.375 rear axle ratio. Basically stock, but with a 2" (OD) sized exhaust system. Stock Hitachi Carb. 60 MPH, around 4,000. Do not even think of getting any useful power below 2,000. Sure, the engine idles about 750, but below 2000 with almost any throttle opening, you are lugging the engine. It is happier at least at 2500, and somewhere around there, or slightly higher, there is enough demand from the engine for the secondary to open. There is a "yellow zone" from 6,500, to 7,000, and 7,000 is a safe redline. 1 Quote Link to comment
edekalil Posted May 26, 2014 Author Report Share Posted May 26, 2014 A lot. This ain't your grandfathers V8. I do not have a 510. I have a 521, with a 4.375 rear axle ratio. Basically stock, but with a 2" (OD) sized exhaust system. Stock Hitachi Carb. 60 MPH, around 4,000. Do not even think of getting any useful power below 2,000. Sure, the engine idles about 750, but below 2000 with almost any throttle opening, you are lugging the engine. It is happier at least at 2500, and somewhere around there, or slightly higher, there is enough demand from the engine for the secondary to open. There is a "yellow zone" from 6,500, to 7,000, and 7,000 is a safe redline. Thanks, My speedo cable is out and I haven't driven my car in a long time. Still getting used to the feel. Quote Link to comment
dr.feltersnatch Posted May 26, 2014 Report Share Posted May 26, 2014 Dont be afraid to open her up and let her sing! 1 Quote Link to comment
datzenmike Posted May 26, 2014 Report Share Posted May 26, 2014 Stock 5.60 X 13 tire and 3.70 axle at 70 MPH is 3,751 RPMs. A 3.90 axle is 3,953 RPMs Any larger diameter tire will be less. 1 Quote Link to comment
