dat*blu*73 Posted May 15, 2014 Report Share Posted May 15, 2014 Doing oil change on l16 whats best oil and weight type of oil filter too ? Herd frams not good what do you think ? Any advice would be helpful. Thanks in advance. Quote Link to comment
MOTO Posted May 15, 2014 Report Share Posted May 15, 2014 What kind of oil was is in it before the oil change? I prefer AC Delco filters and parts, or if you can get a factory part or filter(?). I don't know how much difference a filter would make in an older engine though. probably 10w30 or 40. Maybe 15/40? Unless you have super high miles and she rattles a lot. Then heavier... Edit: how much does your oil pressure change from cold to hot? (psi when cold, psi when at operating temp?) Quote Link to comment
pondking Posted May 15, 2014 Report Share Posted May 15, 2014 GO with the high tops Quote Link to comment
wayno Posted May 15, 2014 Report Share Posted May 15, 2014 WIX oil filters, and I use 20/50 oil Quote Link to comment
metalmonkey47 Posted May 15, 2014 Report Share Posted May 15, 2014 I have some heavy duty 15w-50 with either WIX (napa Gold p/n 1515) OR K&N Quote Link to comment
Guest Rick-rat Posted May 15, 2014 Report Share Posted May 15, 2014 I use 20/50 and NAPA filters Quote Link to comment
ggzilla Posted May 15, 2014 Report Share Posted May 15, 2014 Walmart 10w40 + Fram powerguard. Quote Link to comment
datzenmike Posted May 15, 2014 Report Share Posted May 15, 2014 http://community.ratsun.net/topic/19380-fram-oil-filters-fail/ Fram used to be the best, now are just a name. They have been shown to be poorly made with poor materials and used by cheap ass owners trying to save $3.00. There is no problem finding something better. Oil 15W40 Chevron Dello400 or Shell Rotella T are reasonable. Quote Link to comment
dr.feltersnatch Posted May 15, 2014 Report Share Posted May 15, 2014 I use chevron delo oil and either wix or napa gold filters. Filters are more expensive but worth it. Quote Link to comment
