Gensaiken Posted September 5, 2008 Report Share Posted September 5, 2008 Wondering if anyone else has come upon these doors that just won't lock for some reason. I've tried lubricating to see if it was stuck and it just won't lock. There isn't any rust but some of my spare doors even have the problem. If anyone has a fix for this let me know. Quote Link to comment
jesusno2 Posted September 5, 2008 Report Share Posted September 5, 2008 I gots the same issue along with a hatch that won't latch lol or lock I'm wondering if the key I have is just that wore down that it won't move the tumblers in the right spots?? Quote Link to comment
Gensaiken Posted September 5, 2008 Author Report Share Posted September 5, 2008 I gots the same issue along with a hatch that won't latch lol or lock I'm wondering if the key I have is just that wore down that it won't move the tumblers in the right spots?? Well with my situation I've actually taken the lock out and tried to push down the pole and it will not completely engage. I have maybe one or two spare doors that will do it but all the rest are just jammed. It moves but does not go all the way. Quote Link to comment
hang_510 Posted September 5, 2008 Report Share Posted September 5, 2008 there is a plastic adjustment nut that contacts inside the door. ive seen many bent from trying to make it lock. if the lock arm mechanism is bent, its necessary to straighten as much as possible first. i think it has a small dogleg kink to it... Quote Link to comment
Gensaiken Posted September 5, 2008 Author Report Share Posted September 5, 2008 managed to resolve the issue since the doors need to be closed to lock it. :rolleyes: Although the door I was mainly working with still wouldn't lock even after I made sure door latch was "closed". So that one maybe be legitimately broken. The rest are working good. Quote Link to comment
hang_510 Posted September 5, 2008 Report Share Posted September 5, 2008 the doors need to be closed to lock it. :rolleyes: :glare: :lol: :cool: Quote Link to comment
freaky510 Posted September 7, 2008 Report Share Posted September 7, 2008 :eek::lol::fu::lol::D thats some good shit man i went threw the same thing oneday in a parking lot could leave the datto unlocked i push and push Quote Link to comment
lynchfourtwenty Posted September 8, 2008 Report Share Posted September 8, 2008 hahahaha i was actually going to mention that the doors need to be shut.. my doors lock if im inside my truck but my key wont budge the locks Quote Link to comment
freetheoranges Posted March 23, 2012 Report Share Posted March 23, 2012 managed to resolve the issue since the doors need to be closed to lock it. :rolleyes: Although the door ... still wouldn't lock even after I made sure door latch was "closed". there is a plastic adjustment nut that contacts inside the door. ive seen many bent from trying to make it lock. if the lock arm mechanism is bent, its necessary to straighten as much as possible first. i think it has a small dogleg kink to it... Well with my situation I've actually taken the lock out and tried to push down the pole and it will not completely engage. Bump. Crazy situation. All of these quotes are same problem. Drivers' side door, worked without fail until 2pm today bent the key a tad, super weird. Pulled the assembly apart in the Safeway parking lot before delivering Safeway drugs. Had to zip tie the door to the body, and climb through the passenger side. Pharmacy peeps had a good long laugh. So the problem has to be the spring or the wound coil spring or a small tensioned circlip, all of which no information for repair exists, to my knowledge. New Spring, fixed? or new/ used/ replacement assembly? Quote Link to comment
