1981 210 voltage regulator
  • Replies 9
ALL Nissan/Datsuns has internally regulated alternators from '78 on.
If not charging, the brushes may be bad, alternator no good fusible link blown not allowing the alternator to charge the battery, the battery no good or loose cables. Is the charge light on??
For $10 you can often get a replacement set of brushes for your alternator. May not be the problem but cheap fix if it is.
Auto parts stores will have fuses. I just fill my pockets with fuses from the wrecking yards.
