oldschool80sguy Posted March 26, 2014 Report Share Posted March 26, 2014 The wheels are 15x8.5 and 15x9.5 EP's I am having a hard time finding proper tires. Maybe 245's or 255's. What works? Quote Link to comment
datzenmike Posted March 26, 2014 Report Share Posted March 26, 2014 Not fond of box flairs. They ruin the body lines and look like hell just because it's easier to fit the wrong rims. Big wide tires aren't needed on a small 510 anyway and some home work figuring out the corrct wheel width and off set will go a long way to preserving the 510's good looks. Never never never buy rims and then make the car fit them. This is as bad as marrying your high maintenance girl friend. You'll have to make all the changes for a good fit. Find out what fits and works first then go shopping. Always buy sensible shoes. Most people have terrible taste in rims so go for fit over looks. Quote Link to comment
oldschool80sguy Posted March 26, 2014 Author Report Share Posted March 26, 2014 Not fond of box flairs. They ruin the body lines and look like hell just because it's easier to fit the wrong rims. Big wide tires aren't needed on a small 510 anyway and some home work figuring out the corrct wheel width and off set will go a long way to preserving the 510's good looks. Never never never buy rims and then make the car fit them. This is as bad as marrying your high maintenance girl friend. You'll have to make all the changes for a good fit. Find out what fits and works first then go shopping. Always buy sensible shoes. Most people have terrible taste in rims so go for fit over looks. So, buy tires that fit?, thanks. (The wheels were on the car at purchase and barreled to meet the body line) Quote Link to comment
510T Posted March 26, 2014 Report Share Posted March 26, 2014 The biggest street tire 15's of an appropriate diameter are going to be 225/45 or /50 if you like a taller tire. For wider 15" sizes you will need to look into (D.O.T.) slicks like Hoosiers, they offer a 245/40 and 275/35. 225/45 on a 9" wheel: Quote Link to comment
datzenmike Posted March 27, 2014 Report Share Posted March 27, 2014 So, buy tires that fit?, thanks. (The wheels were on the car at purchase and barreled to meet the body line) Then read the tire size that's on the rims now. Take a good look at the strut clearance. Some tires are wider than others. You can buy a narrower pair for the front with the same height and 'stretch' them to fit a wider rim. If you already have box flairs run any size you like, won't matter. But don't box flair it just to fit something wider. Quote Link to comment
DISLEXICDIME Posted March 27, 2014 Report Share Posted March 27, 2014 Make sure your rear arches under the flare where cut high enough to clear a wide tire or the outer side wall will get shaved off Quote Link to comment
oldschool80sguy Posted March 27, 2014 Author Report Share Posted March 27, 2014 Then read the tire size that's on the rims now.Take a good look at the strut clearance. Some tires are wider than others. You can buy a narrower pair for the front with the same height and 'stretch' them to fit a wider rim. If you already have box flairs run any size you like, won't matter. But don't box flair it just to fit something wider. King Rat, the car had very old racing drags, BFGs with the flying shoe and all. The size read 25x9.5. So that didn't help much when I took them in, the fronts were 205's. For the rear I will most likely have to go with 225's. Hope it doesn't look horrible. Not a fan of the stretched look. The cars been boxed since the early 80s. Molded in full flares, Neely Motosports. Quote Link to comment
datzenmike Posted March 28, 2014 Report Share Posted March 28, 2014 240/75R15 is 29.1" tall and 9.45" wide in 15 inch Quote Link to comment
Just Joel Posted April 2, 2014 Report Share Posted April 2, 2014 Way too tall Imo ^^^^ needs to be closer to 22" Quote Link to comment
datzenmike Posted April 2, 2014 Report Share Posted April 2, 2014 Shit I read 29 instead of 25... thouhgt it was a truck. lol 1 Quote Link to comment
