SU Cold start question
Ryoskatekov
Hey, I have a 83 280zx that I've converted to SU carbs about half an year ago. (don't even try to lure me into EFI again.) winter came and became apparent that it produces shitload of whiteish greyish smoke on cold start with full choke.
 It never did it when it was EFI so it shouldn't be oil. Maybe full-choke is too rich?  if so, is there any way to adjust the choke so iIt won't smoke like hell and make my neighbours mad until the car warms up?  (yes, it goes away after it's wormed up.)  I'm rebuilding the carbs for leaks so that may-be the problem but. looking for answers.  (please don't comeback with BS answers like "go buy Ztherapy dvd" If you don't know it, don't reply)
  • Replies 15
Colder weather shows the steamy exhaust just like your breath in the winter. Carbs with chokes will always stink more than an EFI set up. Try not pulling the choke out all the way or start with full and reduce it slightly once running.
^^ this
Push the choke knob in more as soon as it starts.
Greyish-white smoke is sunburned fuel
Bluish-white smoke is oil
White smoke is water vapor
You may have a combination of different types.
I'm running 20w50 since I have 38mm on the L28.  figured 10w30 was too thin but I don't know
Its not cold enough for white water vapor so I assume its the "greyish" unburnt fuel. wasn't burning oil when it was EFI which is about half year ago and oil level stayed the same.
and another one of my question is "how much smoke is normal" ?
Normal is zero greyish smoke. A little white smoke is normal.
For 240Z carbs, Datsun recommends 10W-30 or 20W. I have no idea what is recommended by S.U. In any case it will have no effect on idling, but only on throttle transitions.
ATF has no clearly defined viscosity. I checked for use in my strut dampers. It can range from 8-12W depending on maker. The thicker the damper oil the slower the slide will raise and the richer it will run as you accelerate when the throttle is opened suddenly.  It's sort of like an accelerator pump.
well every once in a while the oil gets dirty when I check it. some black stuff mixed with the oil but it doesn't seem to be burning too much.
I used 20W50 because I thought slower needle movement meant leaner? lower the needle, leaner right?  I'm using .100 nozzle and SM needles.
I appreciate all the info but What can I do to adjust the choke other than the half choke and releasing it early? (which I will keep in mind)
Will adjustment of butterfly rod thing help at all?
The damper oil is just that. It dampens sudden movement just like a shock absorber. The throttle plate gets suddenly opened and full vacuum is applied to the venturi and needle and seat. If the slide were to suddenly lift the vacuum would be lost and it would not suck in fuel and go lean. This is why the SU is called a constant velocity carb. It tries to maintain a constant air flow through it by changing the size of the venturi to meed demand. You don't want the slide to lift faster than the motor can use it or it will bog.
That is how a manual choke works - you have to manually adjust it as it warms up. The only adjustment is for making sure the butterfly closes all the way when choke knob is pulled out and opens all the way when pushed in.
Exact opposite... Under heavy acceleration, lower dome position will richen the mixture by restricting mass air flow and increasing the air speed over the nozzle drawing more fuel into the motor.
