Komi Posted February 8, 2014 Report Share Posted February 8, 2014 Does anyone know the part number for the drop in replacement k&n air filter for a '68 bluebird 1600 SSS OEM twin side draught intake? The closest I could find on the realm was E-2970. But it seems longer than the datto filter. Some help here would be appreciated. I searched the forums but no luck :( Quote Link to comment
datzenmike Posted February 8, 2014 Report Share Posted February 8, 2014 Get the closest stock filter you can find. K&N are overpriced and no better than the original. 1 Quote Link to comment
ggzilla Posted February 8, 2014 Report Share Posted February 8, 2014 Nissan 16546-22000 Element Subaru 16546-22000 Element Overall size 323mm x 151mm x 60mm Center hole 264mm x92mm 1 Quote Link to comment
Komi Posted February 9, 2014 Author Report Share Posted February 9, 2014 Thanks guys. That's a lead. It's the only SSS datto in Sri Lanka so no one stocks anything! Hence my choice of k&n. Can't be importing filters ever so often. Local k&n agents are a bit slow. They wouldn't know a datto even of it walked up and bit them on their behinds Quote Link to comment
ggzilla Posted February 9, 2014 Report Share Posted February 9, 2014 Measure to be sure K&N 33-2010 [Edit: Maxima filter] Quinton Hazel QAF68 Unifilter UL324-60ST Fram CA2710 Ryco A257 Quote Link to comment
Komi Posted February 9, 2014 Author Report Share Posted February 9, 2014 Found that link. 33-2010 is circular Quote Link to comment
ggzilla Posted February 9, 2014 Report Share Posted February 9, 2014 Can you get Subaru parts in Sri Lanka? They used the SSS filter too. Quote Link to comment
Komi Posted February 10, 2014 Author Report Share Posted February 10, 2014 Yup. Can find easily. Is this the same filter that came on the 1.8liter boxer? I'd prefer to fit a permanent washable filter in there so I can maintain it. It's pretty dusty here so need relatively good filtration too. Hence my choice of k&n. If you guys know a Better bran pls do recommend. I can get it fedexed here Quote Link to comment
Dalesun Posted February 11, 2014 Report Share Posted February 11, 2014 You can got to K&N's wedsite and put in the style filter and size and it will tell you which one. Did it for my weber. Then go into google and put the pn in and search it. Thats how I found the cheapest one. Way cheaper with shipping then it was at the auto parts store. Quote Link to comment
Dalesun Posted February 11, 2014 Report Share Posted February 11, 2014 Omg I dont know how that happened Quote Link to comment
ggzilla Posted February 11, 2014 Report Share Posted February 11, 2014 You hit the Post button 4 times, maybe because it was slow. Ratsun will post the reply 4 times. I wish they would fix that bug. 1 Quote Link to comment
ggzilla Posted February 11, 2014 Report Share Posted February 11, 2014 K&N doesn't carry it any longer. They do have a much narrower one which is same length and thickness. Fram no longer carries CA2710. Too bad since Fram also has washable versions. You can got to K&N's wedsite and put in the style filter and size and it will tell you which one. Did it for my weber. Then go into google and put the pn in and search it. Thats how I found the cheapest one. Way cheaper with shipping then it was at the auto parts store. Quote Link to comment
Komi Posted February 11, 2014 Author Report Share Posted February 11, 2014 Didn't see that option on the site. Will check again Quote Link to comment
Labubre Posted November 15, 2023 Report Share Posted November 15, 2023 anybody? need it too approx 12.6 x 5.9 x 2.36 or 320x150x60mm Quote Link to comment
banzai510(hainz) Posted November 16, 2023 Report Share Posted November 16, 2023 (edited) https://mossmotors.com/37-0880-foam-round-air-filter-2-su https://www.californiaclassix.com/Bernard/SU_Filters.html https://classiccarbs.co.uk/product/su-1-75″-hs6-h6-carburettor-air-filter-cleaner-assembly-kn/ Edited November 16, 2023 by banzai510(hainz) Quote Link to comment
banzai510(hainz) Posted November 20, 2023 Report Share Posted November 20, 2023 (edited) i posted my response here on that thread K&N air filter part number Edited November 20, 2023 by banzai510(hainz) Quote Link to comment
