1973 620 lower control arm pivot bolt
I'm new to ratsun and have a problem removing the lower control arm pivot bolt.... I have beat the hell out of it and no go... 2 ton pulley from auto zone is not cutting it.... I'm swapping drum to disk brakes from a 76 620. Need some expert advise.
  • Replies 5
Do you have custom upper control arms already?
This is not an easy conversion to do, I would not recommend it unless you know how to weld.
How did you decide to do this, someone else did it, you read someone did it?
You did already remove the torsion bar, correct?
  • 3 months later...
