twistedimages Posted January 24, 2014 Report Share Posted January 24, 2014 Here's how: take your foot off the accelerator BEFORE using the brake. It will stop just as fast as a stock 510 if you have tires any wider than the original narrow tires. Stock 510s were tire-limited on braking, they would lock up before maximum force could be applied. Larger brakes will gain fade-free performance , better feel and modulation, but not necessarily stop faster unless you fit more rubber to the road. Ok, what about the NEXT time you step on that brake pedal at the next corner? The stock brakes on a 510 will heat soak at 25 mph on a slight downhill grade- bigger brakes aren't just about braking force, but also the ability to absorb and dissipate heat more effectively. That being said, it sounds like he's already got z brakes for the front, which should help considerably for street use. Digging the SSRs- my vote is for gold- would go nicely with your paint! Quote Link to comment
ggzilla Posted January 24, 2014 Report Share Posted January 24, 2014 Yes, its the same problem 510 brakes had when new. Not up to par with modern brakes. But simply adding HP doesn't make brakes fail; driving faster is a problem as is extra weight. Quote Link to comment
denmarkboy Posted January 25, 2014 Report Share Posted January 25, 2014 Nice looking jump off point , I love reading new builds . This is a very useful site !( if you can get passed people telling you what you can't do !!) . Every datsun on the road is one saved .! 1 Quote Link to comment
aintnobiscuit Posted January 26, 2014 Report Share Posted January 26, 2014 nice dime Quote Link to comment
