hei coil module question.....http://community.ratsun.net/topic/195-hei-wiring-pics-w-writeup/
im sure this had been asked about before just want a little more clarity on the thread
from what it appears, looks like a points style distributor wired with the hei
is this a substitute for the "IC" matchbox only or can it be used in conjunction with the electronic matchbox?
i dont want to fry anything
i have already experienced a burnt coil terminal by accidently using a points coil with my electronic distributor
  • Replies 7
You should already have an EI (electronic ignition) called a matchbox dizzy. If you look you will find a small black box on the side that looks like this...
If you find this you have everything you need for a good ho fat spark. If you don't want to fry something leave it alone, it's already more than you will ever need. Forget about MSD blah blah blah... if your car seems faster with one, it's only because your wallet is lighter.
