Turn signal switch
720LA
I'm wondering if anyone knows an alternative to buying an exact replacement for the turn signal switch. They're so damned expensive and  my 1980 720 has a bad one. It's the non-intermittent, non- cruise control. I'm not really worried about authenticity. Right now it sort of works because I have a rubber band supplying a little bit of pull toward the dashboard. But I always have to remember to turn the left signal off. I'm pretty sure I can figure out a separate switch for the high beams.But finding an aftermarket turn signal switch that would fit the steering column might be kind of challenging. No? Anyone done it?
thanks,
Scott
  • Replies 4
80-82 have the wide spade connectors, anything later has narrow spade connectors, and they are not interchangeable as I recall.
You have an 80 truck, so it is likely a non-tilt column, so there was a lot of changes back then in that period, some of the turn signal wires(green) came off the back of the combination switch as wires into a plug, while others were made for the plug to attach to the combination switch itself, you really need to take a photo of the back of your switch assembly so I/we can see what type you have.
