ANDREW5373 Posted September 19, 2013 Report Share Posted September 19, 2013 I have a 1980 210 original 1.4l 4speed...i am unalble to find a new transmission...so i was able to find a fellow selling a 1974 260z side draft engine with a 4speed including wireing harness...i am in search of information if the engine is reliable and does it have a abundant aftermarket help with parts incase i need to replace and components..and biggest thing is this one of the easier swaps to do? looking for ant input please Quote Link to comment
datzenmike Posted September 19, 2013 Report Share Posted September 19, 2013 You are trying to fit 6 pounds of shit into a 4 pound bag. It's a 6 cylinder and way way way too long to fit in a small 210. It also weighs a ton and the last thing you want is extra weight over the front end. There are 4 cylinder motors that make as much and can make more than an L26 motor. Add to this the 260z had crappy SU carbs for those years. Quote Link to comment
hobbes_the_cat Posted September 19, 2013 Report Share Posted September 19, 2013 This is a terrible idea. Basically it won't fit. Unless you cut a massive amount out of the engine bay and fire wall. Unless you have a ton of experience custom fabricating cars from scratch you need to forget all about this idea. Place an wanted ad for a good trans that will fit. Quote Link to comment
Eagle_Adam Posted September 19, 2013 Report Share Posted September 19, 2013 Not gunna happen, but I have an Aseries 4speed for ya ;) 1 Quote Link to comment
CGS1948 Posted September 19, 2013 Report Share Posted September 19, 2013 Because the L series inline 6 you have your eyes on is a "good deal", or "free", won't magically make your Datto 210 an outstanding car. A shorter version of the L-series, like an L-20 would make a noticeable difference in performance, yet only add about 75lbs or so over the A14. Listen to the folks input on Ratsun here, as many have "been there and done that", and have learned from experience what works, and what doesn't work. Quote Link to comment
ANDREW5373 Posted September 19, 2013 Author Report Share Posted September 19, 2013 shiping from OR to texas would be really exp tho :poop: Quote Link to comment
ANDREW5373 Posted September 19, 2013 Author Report Share Posted September 19, 2013 i fully take everyones advice here very seriously actualy....so the engine will not work so thats outta the question thank you for your help on that...but i know its a far reach but what about the trans...im assuming it wont fit but i want to know from the experts Quote Link to comment
hobbes_the_cat Posted September 19, 2013 Report Share Posted September 19, 2013 You assume correctly, it won't fit. Quote Link to comment
ANDREW5373 Posted September 19, 2013 Author Report Share Posted September 19, 2013 dang it back to the drawing board...my ultimate goal is to get the car back on the road i dont like it collecting dust.....any sugestions on a easy swap..doesnt matter about power...just as long as i can drive my datsun! B) Quote Link to comment
ANDREW5373 Posted September 19, 2013 Author Report Share Posted September 19, 2013 or a more avalible trans that could swap...having a hard time finding direct replacement Quote Link to comment
datzenmike Posted September 19, 2013 Report Share Posted September 19, 2013 The 260Z trans will be a 31.5" long 71B 4 speed so you can do some measuring if you are curious. But it won't fit an A series motor anyway. It would fit an L20B 4 cylinder if you find one.I believe the HL510 (A10) engine cross member will fit the 210 and will allow the L20B to nestle in the bay perfectly. Both engines have the intake and exhausts on the left side and the L20B makes an easy 93 hp and way more lower speed torque than an A14. Quote Link to comment
ANDREW5373 Posted September 19, 2013 Author Report Share Posted September 19, 2013 good to know so sounds like my next hunt will be for a l20b engine and trans... Quote Link to comment
datzenmike Posted September 19, 2013 Report Share Posted September 19, 2013 That would be best as far as easy to do. By easy to do, I mean there's a greater chance of a successful finish. If you are rebuilding the motor it will cost as much to get a Z22 block and rebuild it and put an L20B head on it making an LZ22or stroker motor. A little bigger again. But by all means... research, research, research. Quote Link to comment
Abe Froman Posted September 19, 2013 Report Share Posted September 19, 2013 I believe user name on here "Datsun freak" is located in TEXAS, and has a bunch of A series project's . 1 Quote Link to comment
ANDREW5373 Posted September 19, 2013 Author Report Share Posted September 19, 2013 yeah :blush: he was going to check to see if he one i was going to drive up to pick it up but i think he was unable to find one to fit..if he does i hope he messages me...casue with out a new trans looks like i have to swap out engine......sucks...if i was to sell a runing 1980 a14 engine what would a ratsun price be? Quote Link to comment
heretic Posted September 19, 2013 Report Share Posted September 19, 2013 it's been in the yard awhile but probably worth the drive. Quote Link to comment
Abe Froman Posted September 19, 2013 Report Share Posted September 19, 2013 it's been in the yard awhile but probably worth the drive. That is FWD, he need's a rear drive 210. Quote Link to comment
ANDREW5373 Posted September 19, 2013 Author Report Share Posted September 19, 2013 almost...yea i actually called them on saturday but i really appreciate you looking :thumbup: 1 Quote Link to comment
heretic Posted September 19, 2013 Report Share Posted September 19, 2013 I thought they went front wheel drive in 82' Quote Link to comment
Mikeystoy Posted September 19, 2013 Report Share Posted September 19, 2013 F10 and 310 (cherry) were all fwd 1 Quote Link to comment
ANDREW5373 Posted September 21, 2013 Author Report Share Posted September 21, 2013 ok i just wanted to update everyone....so i started looking into to l20b engine...i dont know if im just not looking in the right places or typing the wrong stuff...but i only found one engine on ebay none any were on cragslist...even did a google search and only found engines on here but they were sold.....im looking for a complete engine...any other sugestions on a common engine that is farley in expensive around 1,500 for engne and trans.......any fellow datsun owners know someone with a extra engine laying around Quote Link to comment
