A_rod510 Posted August 17, 2013 Report Share Posted August 17, 2013 Hey guys I got a 72' 510 4 door and I'm really confused on where the fuel pump is located on it ? When I bought the car it was compleatly gutted and I have no idea on where it is located . You guys might think I haven't looked around or googled enough to find the answer to this stupid question but I've looked everywhere and can't seem to find it . I've seen people with fuel cells but I don't know if that replaces the fuel pump or what it does and where I could purchase one ? I'm currently putting a 95' ka24de in my 510 but don't know the exact location of the fuel pump and I've heard of people getting a 240sx fuel pump and fuel rail but I honestly don't know the correct solution . People tell me it goes inside the fiel tank but im no sure and If anyone could help me out and not act childish it would really help me out . I don't want to give up on this project and I always relate to this site for help but always end up getting insulted . I mean if anyone could honestly help me I would thank you a lot . Quote Link to comment
datzenmike Posted August 17, 2013 Report Share Posted August 17, 2013 Most fuel cells mount the pump inside to keep it cool. A stock tank can be 'converted' with some work to take a submerged pump. In tank would be best but an inline pump will also work and is easier but they can be annoyingly noisy. In line pumps have to be mounted a low and as close to the tank as possible. While there is no upper limit to how much pressure a pump can put out, no pump made can pull fuel vertically more than 30 feet. So low and as close to the tank as you can. Quote Link to comment
A_rod510 Posted August 17, 2013 Author Report Share Posted August 17, 2013 Oh ok thanks and what would you recommend doing for someone on a budget with a stock tank ? And could you show pictures of the different type of tanks if possible ? Thanks Quote Link to comment
thisismatt Posted August 17, 2013 Report Share Posted August 17, 2013 Well, the original fuel pump is mechanical and driven by (attached to) the engine, so if you're missing the original L series motor, then the car doesn't have a fuel pump. Your KA24DE would have had an in-tank pump, so it's up to you to figure out which way you want to go. The easiest would be to go with an inline pump... Quote Link to comment
SupDoc Posted August 18, 2013 Report Share Posted August 18, 2013 You can send your stock gas tank to goichi1. He can weld a 300zx fuel pump into the tank. That's what I did for my KA swap. Quote Link to comment
datzenmike Posted August 18, 2013 Report Share Posted August 18, 2013 Oh ok thanks and what would you recommend doing for someone on a budget with a stock tank ? . A $50 in line fuel pump and a couple of gear clamps. Be sure it's capable of EFI fuel pressure for the injectors 40-50PSI Quote Link to comment
