j_boy_619 Posted July 16, 2013 Report Share Posted July 16, 2013 That, I can can hook you up with. I know where there are 3 or 4 sedans in a wrecking yard. it's about an hour away though.. I do need some parts from there too. I'll see if I can make it down there. nearly 100 all this next week though I just got an offer from another ratsuner regarding the window, thanks though. As much as it would suck to see a B210 at a junk yard, it would be nice to find one there as a place for parts. Quote Link to comment
Dguy210 Posted July 16, 2013 Report Share Posted July 16, 2013 Well I knew it wasn't going anywhere.. then I heard the other day he was going to scrap it .....OH no you are not! so it had to be done... so now I have to get the rest of parts that he has A12 thats worn out.. an A15 that makes noise. and who knows what else. Do you have plans for that A12? I need some parts for an A12 longblock I have such as the flywheel, flywheel bolts, motor mounts etc... I was going to post a wanted ad I just haven't gotten around to it yet... 1 Quote Link to comment
B210GX Posted July 16, 2013 Author Report Share Posted July 16, 2013 Do you have plans for that A12? I need some parts for an A12 longblock I have such as the flywheel, flywheel bolts, motor mounts etc... I was going to post a wanted ad I just haven't gotten around to it yet... I will have to see whats all there. He works at the same place, except he works nights. opposite shifts. I will help if I can. by mounts do you mean the rubber insulators or the actual steel mounts on the side of the block? Those, I may have here now. Quote Link to comment
Dguy210 Posted July 16, 2013 Report Share Posted July 16, 2013 I will have to see whats all there. He works at the same place, except he works nights. opposite shifts. I will help if I can. by mounts do you mean the rubber insulators or the actual steel mounts on the side of the block? Those, I may have here now. Cool thanks! I need the actual steel mounts for the side of the block. The rubber mounts were still on the crossmember strangely enough. Quote Link to comment
