L20B W/ Duel Side Drafts
Nismo1970
Well I dunno about everyone else, but Hainz just convinced me to throw them on my motor. LOL probably will throw them on friday, and post some oics of the results.
Thank you everyone for your input on this, it helped out alot.
  • Replies 33
Normal for the most part I would say. I never known a pair of triples that didnt spit up once in a while. Also if you pump before starting sometimes fuel runs out.
Well leaking fuel is a different story, they shouldnt ever just leak fuel, if they do I would most def check the floats. Even with the floats set perfect if you pump to start and the angle is right its going to run out into the filter. Fuel mist comes out when they burp too again regardless.
