a.d._510_n_ok Posted June 29, 2013 Report Share Posted June 29, 2013 this thing lights up, loads a cd and plays it buuuuuuut I can just barely hear the music and the volume is at full blast.......? Quote Link to comment
datsunaholic Posted June 29, 2013 Report Share Posted June 29, 2013 You have the speakers hooked up to the speaker wires and not the pre-amp outputs? Quote Link to comment
a.d._510_n_ok Posted June 29, 2013 Author Report Share Posted June 29, 2013 You have the speakers hooked up to the speaker wires and not the pre-amp outputs? I've actually tried one speaker on all four leads separately so I should have came across at least one regular speaker lead. the display is reading "equalizer" but I was assuming that the eq is a built in.....? Quote Link to comment
datzenmike Posted June 29, 2013 Report Share Posted June 29, 2013 Switch equalizer to OFF (turn vol down first) Quote Link to comment
datsunaholic Posted June 30, 2013 Report Share Posted June 30, 2013 I've actually tried one speaker on all four leads separately so I should have came across at least one regular speaker lead. the display is reading "equalizer" but I was assuming that the eq is a built in.....? What are you using for speaker (-)? Most head units don't use chassis ground for speaker (-) and don't use a common speaker (-) either. Have you searched online for the wiring diagram? I'm assuming this isn't a new unit with the wires all labelled and a manual onhand. Quote Link to comment
cruznude Posted June 30, 2013 Report Share Posted June 30, 2013 Yea just do like Mike said, Turn off EQ you don't have and back to FM and them turn it UP!!!!!!!!!!!!! Quote Link to comment
