izzo Posted May 21, 2013 Report Share Posted May 21, 2013 I am looking for a 510 manual gas pedal. I put that in my status. If you have one, pedal, and metal rod that goes behind the pedal itself to the cable let me know.. There was a little talk that they are the same from auto to manual, and that the brake pedal is different. But thats not 100% true, only 50%.. The brake pedal is different. The automatic is wider vs the manual pedals. However, the gas pedal is also positioned more to the left as well as the rod itself. Here you can see I switched my 510 from auto to manual, with just switching the gas/clutch pedals. They fit, but man is that brake pedal close to the gas pedal. Hasn't been an issue and I don't really seeing it... Reason why? well when I hit the brake hard enough to slow down, stop, or emergency stop I automatically hit the clutch pedal same time. So it's not going to matter if I fat foot it and hit the gas too, as the clutch is depressed and I won't go anywhere... When I just want to slow down a touch.. I barely touch the brake pedal. it's funny even having giant feet, how much your brain subconsciously thinks about where they are and what pedals you are hitting... how hard, etc. Anyways. Skib, Eagle adam. Here is the manual pedals with the auto gas pedal Quote Link to comment
datzenmike Posted May 21, 2013 Report Share Posted May 21, 2013 Look down at the front of the gas pedal. There are two screws attaching it to the floor. Take them out and look hard... there's a third hole to the right so it can be moved over and share the middle hole. Just bend the metal rod above it to suit. Isn't that easy????? Quote Link to comment
izzo Posted May 21, 2013 Author Report Share Posted May 21, 2013 Ill check here in a minute. I haven't pulled the carpet out of the floor yet! Just lifted up the door mat to vacuum under it :rofl: Sounds like draynor had the same thing going it, as if it was different all together. the position of the plastic where it screwed to the floor was offset on the gas pedal vs auto pedals. Ill post what I find later tonight. Quote Link to comment
izzo Posted May 22, 2013 Author Report Share Posted May 22, 2013 Alright. The holes in the floor. I did some searching, there is a third spot for a screw that I will need to drill out.. However, I won't be able to bend the gas pedal correctly to work right / line up right. I don't have the correct tools to do that (vise, torch etc). Here is a pic of the manual gas pedal location. In the pic you can see where the automatic pedal was screwed down. owner of this dime drilled the second holes where they were marked from factory, then found the manual rod. Quote Link to comment
datzenmike Posted May 22, 2013 Report Share Posted May 22, 2013 Said it was easy... and looks great! Quote Link to comment
izzo Posted May 22, 2013 Author Report Share Posted May 22, 2013 ^^^ hahaha. Thats not my doing! That's someone elses. It is really easy. I was just pointing out the info more or less, and asking if someone had a manual gas pedal :D So now people know, there is a difference. holes are pre-marked on the floor. Just need to drill, and find a manual rod... Quote Link to comment
Draker Posted May 22, 2013 Report Share Posted May 22, 2013 Let me check my stash. I got 2 extras. Quote Link to comment
izzo Posted May 22, 2013 Author Report Share Posted May 22, 2013 Sweet thanks Draker! Let me know, probably pick it up at canby. No hurry on this. Quote Link to comment
BlkSSnCPT Posted June 14, 2013 Report Share Posted June 14, 2013 how does the pedal clip on the backside??? i have mine but idk how it's supposed to connect to the actual metal part :blush: ... -Rob Quote Link to comment
Draker Posted June 14, 2013 Report Share Posted June 14, 2013 Shit.. just saw your reply.. Did you find a pedal? I've still got some I think. Quote Link to comment
Eagle_Adam Posted June 14, 2013 Report Share Posted June 14, 2013 i sent him a set Quote Link to comment
Laecaon Posted June 15, 2013 Report Share Posted June 15, 2013 I have a bigger problem with the brake pedal too close to the tranny tunnel, than the gas pedal too close to the brake pedal. My friend cant drive my car because his size 13 shoe hits the tranny tunnel and the brake pedal at the same time. Quote Link to comment
