sick620 Posted May 13, 2013 Report Share Posted May 13, 2013 I have a 76 620, how do I tell if my distributor can have a pertronix bolted in? Quote Link to comment
darrel Posted May 13, 2013 Report Share Posted May 13, 2013 There should be an application guide someplace. Quote Link to comment
motavated Posted May 13, 2013 Report Share Posted May 13, 2013 Let me explain it better. Quote Link to comment
darrel Posted May 13, 2013 Report Share Posted May 13, 2013 http://www.pertronix.com/support/ignitor-kit/default.aspx probably a nippondenso number Quote Link to comment
sick620 Posted May 13, 2013 Author Report Share Posted May 13, 2013 thanks alot.. motivated... guess what I just ordered a pertronix, and I have the distributor posted above, does anyone want to sell me an old points dizzy that dosent have the ring as posted above???? Quote Link to comment
sick620 Posted May 13, 2013 Author Report Share Posted May 13, 2013 what about this one?? Quote Link to comment
motavated Posted May 13, 2013 Report Share Posted May 13, 2013 this is the one you need. If it is not like this. No worky... Check it out. Quote Link to comment
motavated Posted May 13, 2013 Report Share Posted May 13, 2013 You can always grind it down but I would not risk it man. I just bought a matchbox instead... I will wait until the kit come over. The center magnet will not fit if its the wrong distributor. You can then experiment from there. Quote Link to comment
banzai510(hainz) Posted May 13, 2013 Report Share Posted May 13, 2013 I had one of those Distributors and rebove the rotor and had it machine off. Most of those L20 single point will work if you machine the ring boss off. However I had one where it wouldnt line up right. Is obvious when you mount it on the plate. the moodule will be to cloe to the rotor shaft not letting the magnet ring on. The application say single point L16. meaning 69-69 or a import single point dizzy. However they will fit the Mishibishi and SSS dizzys also Quote Link to comment
sick620 Posted May 14, 2013 Author Report Share Posted May 14, 2013 im thinking about grinding it off? has anyone else tried that with sucess? Quote Link to comment
crackerjack69 Posted May 15, 2013 Report Share Posted May 15, 2013 You can score the remote module dizzys offa 78 620 pretty easy. People don't see them as gold plated like the matchbox. Then throw a 4 pin GM HEI module mounted near the coil. I did on my truck, worked real good and way more affordable EI than the matchbox. Plus, if you're parked somewhere sketchy, you can throw the module in your pocket as theft deterrent. Quote Link to comment
sick620 Posted May 15, 2013 Author Report Share Posted May 15, 2013 somebody sell me one of these old distributors please! Quote Link to comment
crackerjack69 Posted May 15, 2013 Report Share Posted May 15, 2013 I just gave a pile of them to Banner when I had to move. Mebbe hit him up FB style. Quote Link to comment
motavated Posted May 15, 2013 Report Share Posted May 15, 2013 I wonder if it will fit over a 6 cylinder dizzy and make it act like a 4 banger.... Quote Link to comment
sick620 Posted May 16, 2013 Author Report Share Posted May 16, 2013 what is banners facebook name? Quote Link to comment
sick620 Posted May 25, 2013 Author Report Share Posted May 25, 2013 i just got a 78 dizzy, with the box, it dosnt look like my pertronix will work, and the box dosnt have the wiring clip... What are my options now? do I need the big black box? why cant the dizzy just go straight to my coil? Quote Link to comment
sick620 Posted May 25, 2013 Author Report Share Posted May 25, 2013 I see now that I can run the HEI module.. I just used the search function ;).... Do I have to have a 79 type coil? will my 1.5ohm with resistor work? Quote Link to comment
banzai510(hainz) Posted May 25, 2013 Report Share Posted May 25, 2013 Yes you can make it work but be EZ to just get a 78/79 EI coil. Quote Link to comment
