SU Float 38mm
I need a new float for my SUs. The front float has fuel in it, and is causing my float bowl to overflow.
Do you have a float?
Do floats from roadsters or Z cars work?
Part numbers?
  • Replies 8
brass floats? take it out and drill a tiny hole let the fuel drain out and solder it back up just be sure that the fuel as had a chance to evaporate for a few days
And bam, Fixed. Hollar to Eagle Adam!
He had a spare carb, I pulled a plastice float from it. I had brass ones. But none the less my car is running well again.
It would still be good to know, as I found it very hard to find info on. I'll get pics up, or measurements.
Different float type, fuel level in bowl might be different with this float and need adjustment.
You know the saying "when it rains, it pours"?
Well the new float helped, but did not restore the carb. I actually found a loose carb to manifold nut. Vacuum leak! Now why did my float die, and the nut back off at the same time?
