Stoffregen Motorsports Posted May 3, 2013 Report Share Posted May 3, 2013 If someone cut off the barb, slip a -6 tube nut on there and flare it, then use a -6 union and run it to your SS hose. That's if it's 3/8. If it's 5/16, which would be -5, you're screwed. Nobody makes -5 anymore. You could always braze on a fitting or have a shop do it, or get a new fuel rail. Quote Link to comment
SR20DETdatsun510 Posted May 3, 2013 Author Report Share Posted May 3, 2013 This is what the current inlet looks like...Looks like there might have been something on there before. It was previously hooked up with reg Rubber Fuel hose and a -6 Barb Fitting... Just don't want to cheap out like that now tho... Quote Link to comment
Rustbucket Posted May 3, 2013 Report Share Posted May 3, 2013 Surprised you didn't just go for an aftermarket rail. Seems like it would have solved all your issues, and looked pretty while doing it! Quote Link to comment
Uber Deaf One Posted May 3, 2013 Report Share Posted May 3, 2013 Surprised you didn't just go for an aftermarket rail. Seems like it would have solved all your issues, and looked pretty while doing it! +1. All that $$ into this build, might as well go with an aftermarket fuel rail. Quote Link to comment
SR20DETdatsun510 Posted May 3, 2013 Author Report Share Posted May 3, 2013 I didn't go with an after market fuel rail because of the type of Greddy Plenum I have and the good Sard 850cc side feed injectors i have. The S14 SR runners curl up from the head. The Plenum and IAFC are pretty close to the fuel rail as is and I didn't want to pop on a fuel rail and find out it doesn't fit. See in this pic where is it tucked way down between the Plenum and Head? 1 Quote Link to comment
SR20DETdatsun510 Posted May 3, 2013 Author Report Share Posted May 3, 2013 Plus I don't need a huge side feed fuel rail for 350-400HP... Quote Link to comment
Wicked Saint Posted May 3, 2013 Report Share Posted May 3, 2013 Looks like you already got squared away but for what it's worth I have -6 fittings welded onto my FPR and return. I can send ya a pic if you like Quote Link to comment
SR20DETdatsun510 Posted May 3, 2013 Author Report Share Posted May 3, 2013 Sure, pics are worth 1000 words! Quote Link to comment
Wicked Saint Posted May 3, 2013 Report Share Posted May 3, 2013 I'll post a pic as soon as I get home if the kid lets me go into the garage Quote Link to comment
SR20DETdatsun510 Posted May 4, 2013 Author Report Share Posted May 4, 2013 Something like that could work too! Cool Wedding ring too bro! Haha Quote Link to comment
Wicked Saint Posted May 4, 2013 Report Share Posted May 4, 2013 Heh, thanks. Marcus had one welded on the stock one so when I bought this nismo one I had a friend do the same then leak checked it to be safe Quote Link to comment
