a2lowvw Posted April 16, 2013 Report Share Posted April 16, 2013 i guess i need some help/clarification. I am putting a l20b into my 521 with a longtail (260z) 5speed. i wasn't smart enough to pull the flywheel when i pulled the tranny from the jy. I plan on using my "truck" ... i know everyone says use exedy clutches but I am left with options. It appears I can use a 200mm flywheel and run a roadster clutc, 225mm flywheel and clutch and a 240mm clutch from the newer ka's. Logic says use the largest clutch assembly possible to have the most surface area, although something with a higher clamping rate on the pressure plate also raises question to use seems like one of the cheapest options for flywheel http://www.allreplacement.com/product/3856 and this seems to be the cheapest option for clutch flywheel combo http://gripforce.com/product/exedy-oem-clutch-kit-and-f1-oem-flywheel-nissan-pathfinder-720-d21-pickup-2.0l-2.4l.html the reason i am asking is i don't have a flywheel ;) Quote Link to comment
banzai510(hainz) Posted April 16, 2013 Report Share Posted April 16, 2013 Im thinking 240mm is overkill see what Datzenmike says Im in agreement with you bigger the surface better. However the cast 225truck and 240s weigh a ton. a varible here is the Throw out collor to get with the clutch set up.If wrong size youll be pulling the trans again. Quote Link to comment
a2lowvw Posted April 16, 2013 Author Report Share Posted April 16, 2013 Im thinking 240mm is overkill a varible here is the Throw out collor to get with the clutch set up.If wrong size youll be pulling the trans again. im sure the 240 is way more clutch than it would ever need. however price and availablitiy is nice. i do have a couple throwout bearing collars that i have pulled from the wrecking yards... Quote Link to comment
kelowg Posted April 16, 2013 Report Share Posted April 16, 2013 Match clutch with flywheel u already have. Unless ur building some monster L20, that should work. Quote Link to comment
a2lowvw Posted April 16, 2013 Author Report Share Posted April 16, 2013 Match clutch with flywheel u already have. Unless ur building some monster L20, that should work. the l20 i pulled had an auto mated to it and I don't have a flywheel .... updated the main post Quote Link to comment
banzai510(hainz) Posted April 16, 2013 Report Share Posted April 16, 2013 Frank in Everett has tons of flywheels I bet. if ever down south I got a 225mm flywhee give you free. a 225 mm Daiken stage 1 (importrp.com )will be more than enough but the price is 200 for that kit. Quote Link to comment
datzenmike Posted April 16, 2013 Report Share Posted April 16, 2013 $175 for new flywheel too? I'd say go for it. Says it fits 1983 - 1986 Nissan 720 Pickup (2.4L SOHC 4cyl, 2WD; 4WD) so it will fit the L20B crank. Probably 29 pound if from a truck. But so what truck 225mm are 29 pound also. You will need a pilot bushing in the end of the crank, about $3. Quote Link to comment
a2lowvw Posted April 23, 2013 Author Report Share Posted April 23, 2013 clutch kit came today. seems like its legit. flywheel is def heavy, holy shiat. Quote Link to comment
banzai510(hainz) Posted April 23, 2013 Report Share Posted April 23, 2013 flywheel is def heavy might loose 10 hp Quote Link to comment
