XXL Posted April 13, 2013 Report Share Posted April 13, 2013 SOLVED Can someone out there with access to a waterjet make me a couple of brackets for my seatbelt conversion? Oh... did I mention I'm poor :( Here's what I need-- qty 2x, made from 3/16" steel. These will be used to mount my retracting seatbelts to the stick anchor point. If you can help, and work realllllllllllly cheap, please PM me. Quote Link to comment
RedBanner Posted April 13, 2013 Report Share Posted April 13, 2013 Id suggest just buying a short peice of 1 inch flat stock, and drill your self the "bracket" 1 Quote Link to comment
Dawa Posted April 13, 2013 Report Share Posted April 13, 2013 +1. ^ this is a piece that althought it does have to be strong, it DOESNT have to be precisely machined. go buy some metal at home depot and drill some holes into it. cut it with a hacksaw, cut off wheel, dremel, whatever. 1 Quote Link to comment
highdesertdatsun Posted April 13, 2013 Report Share Posted April 13, 2013 you spent to much on your heater pipe conversion no money left for seat belt bracket keep it simple . Quote Link to comment
datzenmike Posted April 13, 2013 Report Share Posted April 13, 2013 If I told you how much money I have in this little project (not to mention TIME), you would probably have a mild heart attack and hit your head on the keyboard. Hint: a SINGLE stainless elbow is $30... I have 3, plus straight tubing, plus the aluminum tube I started with, plus the copper parts, plus AN fittings, plus, plus, plus... :w00t: 1 Quote Link to comment
