620 KC overhaul
  • Replies 135
Whew, I was getting ready to multi-quote, but I think I'll skip that.
I hadn't really thought about cutting it out for the exact reason you guys were saying, it provides reinforcement to the frame. It is ugly and unnecessary, so I will likely cut it out and replace it with 1 or 2 round tubes, something like 1-1/2" dia.
Now the updates! I made a great breakthrough today... something that I should have done long ago.
The other week I got started on it, the 240SX I bought for the suspension and engine/transmission.
And tonight I got it to a point where I can wheel it into the backyard. Im going to hang onto it for now.Cpl620 has got me thinking IRS rear swap... but I think that's a little too much right now. I want to drive this thing already!
My driveway hasnt been like this in forever!
Tomorrow I will cut off the rear bumper from the 620, and on Sunday I will pull the bed, remove the engine temporarily, and pressure wash the frame. Im saving this link (http://www.agscompany.com/automotive/brake-fuel-transmission-lines/nicopp/11) for when I get to the brakes. I wont be using steel lines. Question if anyone gets this far. Is the bed held on by anything more than 6 bolts, 3 on each side?
Nice! If you have the room just stash that thing. You can sell a subframe with everything for $100 or so.
The bed only has those 6 bolts. Or is it 8?
Edit: yeah I had 8. 2 in the front and back on each side. From the looks of how your numper is welded on though, they make have taken out the bolts that were there.
I found the last two bolts, they were close to the bumper, and a pain to get at. Fortunately as well, the bumper was bolted on! I didnt notice it when I took it, but in the above picture you can see 2 bolts on the far left, alternating directions. They came out quite easily.
I asked a neighbor to borrow a pressure washer, and will get to cleaning the frame tomorrow.
Using the cab for storage now
Lucky me I have a few of those -_-  Definitely going to make a mess, but it must be done.
So I'm contemplating the fuel cell location, and think I've decided what to do. I originally thought about putting one in the location the original tank was, along the passenger side between the frame and drive shaft. I have about 13-14" to work with width wise, but cant find any cells to match. Instead, I will remove the spare tire mounting location, and set the cell there. I'm believe there is about 34-35" within the frame rails, and 19" depth between the cross supports. I'm not sure of the height I want, but it will probably be 10" which seems to be a common height for 33" length tanks.
I will need to figure out if the exhaust will run into any issues here, but maybe I will put the muffler nearer the bed, and run the pipe the rest of the way for better clearance.
May be a little while for real updates, other than grinding/cleaning/painting areas that I wont be doing things to. I need to save up for the things I need next: Fuel cell, Fuel pump, Fly wheel, clutch & pressure plate, Fuel and brake lines, drive shaft, and the metal to mount the fuel cell.
Rci 2172a is the tank I put in the back of my 620 build 17 gal 30x17x7. If you plan on a rear sub frame get a smaller one I ended up moving my tank back 4 inches so I had a lot of cutting
Thanks, that's just what I'm looking for. I was hoping to get a 20-22 gallon, but I think thats going to be a bit too large.
Started to clean up the frame. I had to re-weld some things because they were the first welds I did, and well, they were shit. I took my wire wheel to the front, and mad a ton of dust. Sprayed some OSPHO (phosphoric acid) over the bare metal to protect it until I'm ready to paint.
Thanks guys. Its been really cold outside for the past few days so I have been staying in the house. When I say cold, I mean 28-34 degrees, so I know its nothing compared to what some of you have to deal with.
I have an electric heater, but I am waiting on some 10g wire to upgrade the existing 12g I use for my compressor/welder. I would rather not fry my wiring and burn the garage down using the 12g. Once thats in, I will get going on some more progress and likely start insulating the walls to keep the heat in.
So I wired up the heater after doing some math. As long as I dont turn it to its highest setting, I wont exceed the amp rating of my current wiring. That warms it up a bit in there, but I havent done much.
I continued wire-wheeling the frame, got back to the torsion rod crossmember.
Can some one tell me what the tabs were for? I dont remember, and trying to figure out if I need to keep them or not.
And are these holes/caps from the factory?
More of the same. I think I will need another wheel before this is over. Got most of the way down the passenger side, and halfway down the driver's side. I will flip the frame over to get the underside when I finish with the top. In the areas I cant reach, I will pull out my pot blaster. I didnt want to do the whole thing with it because of the mess it makes.
