OK, how hard is it to remove the oxygen sensor?
Telkwa
  • Replies 9
Now that it's idling again (thanks datzenmike) I'll definitely heat it up and soak with Aerokroil.  Let it cool a bit and do it again.  Amazon has a bunch of Nissan 720 O2 sensors.  This one appears to be correct (?).  I don't know if our local stores will have one for such an old rig.
Lucked out and got a bite on it with a standard 7/8" box end wrench.  I only had a few degrees of freedom to move the wrench, so if it hadn't broke free relatively easily woulda been a different story.  Our local NAPA store had a Bosch replacement.  I had to cut the old wire off and crimp to the Bosch, but they included a piece of heat shrink tubing in the box.  That was thoughtful.
