datzenmike Posted May 4, 2007 Report Share Posted May 4, 2007 Is there any chance that when a member receives a P/M that there could be a flashing notice to draw attention to the fact? There is another forum that does this and I guess I got spoiled, or I have a blind spot or something. If not, it's OK, it would just be a nice convenience. Quote Link to comment
71-521 Posted May 5, 2007 Report Share Posted May 5, 2007 If you go to your user control panel and select "edit options", there is a box you can check that says: "Show New Private Message Notification Pop-up" then it (a pop-up) will happen when you open a new window and give you the option to open the PM in a new window so you can continue browsing on the page you originally selected.... hope that helps ya... Quote Link to comment
datzenmike Posted May 6, 2007 Author Report Share Posted May 6, 2007 Yes it will! Thanks ... old dogs and new tricks, eh? I always wondered what that switch on the dash did. You know, the one next to the lighter, you twist it, turn it, push and pull on it but nothing ever happens. Then you try it one night, and the dash lights dim..... well that's me!!! Quote Link to comment
Icehouse Posted May 6, 2007 Report Share Posted May 6, 2007 Me to Mike :D Except I get the wiring diagram and research it for an hour haha Quote Link to comment
Draker Posted January 1, 2017 Report Share Posted January 1, 2017 To end 2016, I give to you all.. A DatzenMike newb post and an ultimate necro bump. Here is to 2017. 7 Quote Link to comment
