chebetio510 Posted February 21, 2013 Report Share Posted February 21, 2013 just finished up my second ka swap, did my 620 first.. got that running no problem. but i have hit a dead end on this.. I have Fuel getting to the rail,, spark... but wont start.. if i spray starting fluid in throttle body car starts and runs off of the starting fluid but wont idle dries out.. there is power at injectors.. i had pulled out fuel rail and cracked and noticed fuel injector spray is extremely weak almost nothing. y fuel lines are not inverted.. already tried swapping ecu's thats not it.. swapped coils and ignitor tht didnt do it either so i know its fuel related.. any help or knowledge would be appreciated Quote Link to comment
Draker Posted February 21, 2013 Report Share Posted February 21, 2013 What is your fuel pressure? Quote Link to comment
DeviousPsycho620 Posted February 21, 2013 Report Share Posted February 21, 2013 My ka runs at 44 psi. Quote Link to comment
FiveTenzo Posted February 21, 2013 Report Share Posted February 21, 2013 Fuel pump? Check ecu codes? Quote Link to comment
chebetio510 Posted February 21, 2013 Author Report Share Posted February 21, 2013 pump im running is brand new and shooting shit load of pressure, havent put a pressure gauge to it.. but i honestly doubt its fuel sumo.. a test i did do was wire up an injector while the fuel rai was out and hooked it up strait to battery.. and tht injector sprayed like no tomorow.. Quote Link to comment
Draker Posted February 21, 2013 Report Share Posted February 21, 2013 Run codes and report back Quote Link to comment
chebetio510 Posted February 21, 2013 Author Report Share Posted February 21, 2013 will the ecu pick up codes on cranking only? only time it ran for a couple of seconds would be when i sprayed ether? Quote Link to comment
DottiBlue Posted February 21, 2013 Report Share Posted February 21, 2013 Fuel lines hooked up backwards? Quote Link to comment
Draker Posted February 21, 2013 Report Share Posted February 21, 2013 It will pick up codes when you turn the key to the on position. Quote Link to comment
chebetio510 Posted February 21, 2013 Author Report Share Posted February 21, 2013 lines are not backwards... tripple checked that.. pulled codes have code 13 which is etc code.. nothing else Quote Link to comment
Draker Posted February 21, 2013 Report Share Posted February 21, 2013 Do you have fuel in your gas tank? Quote Link to comment
chebetio510 Posted February 21, 2013 Author Report Share Posted February 21, 2013 yup threw 5 gallons i there. put a injector noid light to check for pulse, pulse is very weak. light almost doesnt turn on very dim.. Quote Link to comment
D52E Posted February 21, 2013 Report Share Posted February 21, 2013 Do you have a different vehicle that you can use to test your ECU? Plug it your suspect ECU and see if a known good vehicle starts? I recommend against trying someone else's ECU on your vehicle just yet but it would be nice to confirm it is wired good. Quote Link to comment
philcas1987 Posted February 22, 2013 Report Share Posted February 22, 2013 run the ecu numbers. I have seen people mistakenly use a ka24e ecu or sentra....Sr. They all plug in the same un less its later model Quote Link to comment
chebetio510 Posted February 22, 2013 Author Report Share Posted February 22, 2013 Do you have a different vehicle that you can use to test your ECU? Plug it your suspect ECU and see if a known good vehicle starts? I recommend against trying someone else's ECU on your vehicle just yet but it would be nice to confirm it is wired good. i usesd this ecu in my Datsun 620 with a ka swap i rescently just finished and the ecu worked.. my truck started up just fine,, swap is wired the same Quote Link to comment
DISLEXICDIME Posted February 22, 2013 Report Share Posted February 22, 2013 bad ignition switch Quote Link to comment
chebetio510 Posted February 22, 2013 Author Report Share Posted February 22, 2013 bad ignition switch how or y? Quote Link to comment
napz510 Posted February 23, 2013 Report Share Posted February 23, 2013 Maybe you don't have power on your ecu when you put your ignition to start. Quote Link to comment
DISLEXICDIME Posted February 23, 2013 Report Share Posted February 23, 2013 if the switch is going bad the car will crank but not fire Quote Link to comment
Kisor Posted February 23, 2013 Report Share Posted February 23, 2013 Double check all grounds to the ecu. Injectors receive 12v+ with ign on and the ecu provides the ground to open them. You may have a loose or incomplete ground to the ecu and it is back feeding from somewhere else.If your noid is weak there is prob a circuit issue. You can make a crude "loading test light" to test the 12v+ supply using a brake light bulb or equivalent. 7443 bulbs work good, they have pins that are easily bent out to hook to. If you are using a multimeter to see if voltage is present it won't show a high resistance if there is a problem in the circuit. loading the circuit will reveal this type of issue. 1 Quote Link to comment
datson4life Posted December 20, 2013 Report Share Posted December 20, 2013 what was the issue???? im going thru the same thing right now Quote Link to comment
chebetio510 Posted December 28, 2013 Author Report Share Posted December 28, 2013 what was the issue???? im going thru the same thing right now intake leak , make sure ur intake and mac are all hooked up and sealed properly, 1 Quote Link to comment
