Lobo Posted February 21, 2013 Report Share Posted February 21, 2013 ok im completely lost on everything on my 411 question i have at the moment. i heard that a carb off a L motor will fit on my j1300 is that true that it will bolt right on Quote Link to comment
datsunaholic Posted February 21, 2013 Report Share Posted February 21, 2013 I believe the bolt pattern is the same, but the similarity ends there. I suppose I could actually go look. I have a J-series with no carb on it, and lots of L-series hitachis loose. But they're at home. Quote Link to comment
Lobo Posted February 21, 2013 Author Report Share Posted February 21, 2013 That would be great I'm thinking if the bolt patterns are the same i might order i Webber for it the carb i have in there now needs rebuilt plus is missing parts off of it matter a fact there us one part on the carb they had a wire cap plugging a hole lol Quote Link to comment
Noiin Posted February 25, 2013 Report Share Posted February 25, 2013 i have pretty much the same question. What carb. can i use to replace my Nikki carb.? Quote Link to comment
Lobo Posted March 1, 2013 Author Report Share Posted March 1, 2013 hey do you guys know witch model hiatchi carb they put on the j13 in 66 on the 411 trying to find a rebuild or know were on the carb i can look Quote Link to comment
datsunaholic Posted March 1, 2013 Report Share Posted March 1, 2013 It wasn't a Hitachi. It's a Nikki. I don't know the model number. Quote Link to comment
Conner Posted March 1, 2013 Report Share Posted March 1, 2013 I had my carburetor for my truck rebuilt by Chicago Carburetor. It cost around $225 including shipping. They did a nice job. Very bottom of the page: http://chicagocarburetor.com/carburetors-remanufactured.php?c=118 Quote Link to comment
Noiin Posted March 1, 2013 Report Share Posted March 1, 2013 i went ahead and bought a NIKKI D2630A-7B kit for my NIKKID2630A-7A ill let you know if if works out when it gets here Quote Link to comment
Lobo Posted March 3, 2013 Author Report Share Posted March 3, 2013 So after a ton of homework i found out my carb is off a 67-68 520 pickup with the j13 motor Quote Link to comment
Noiin Posted March 4, 2013 Report Share Posted March 4, 2013 the kit works but i think the rubber ring is for a glass fuel bowl. witch i dont have. damn car wont start up again. no idea what it is.. Quote Link to comment
Lobo Posted March 7, 2013 Author Report Share Posted March 7, 2013 so does anyone know were or what other cars i can get a headlight switch from mine is bad can i just use one out of a 521 truck i can get my hands on one of those Quote Link to comment
Noiin Posted March 7, 2013 Report Share Posted March 7, 2013 i used the one from my 520 Quote Link to comment
MikeRL411 Posted March 7, 2013 Report Share Posted March 7, 2013 so does anyone know were or what other cars i can get a headlight switch from mine is bad can i just use one out of a 521 truck i can get my hands on one of those Punctuation doesn't hurt! It actually improves comprehension. 1 Quote Link to comment
Lobo Posted March 7, 2013 Author Report Share Posted March 7, 2013 Hell after messing with the switch after a bit the headlights came on. so i think it just has some Corrison in it. At least i hope Quote Link to comment
Lobo Posted March 7, 2013 Author Report Share Posted March 7, 2013 Tore my light switch apart today. Cleaned all the brass connections works great yay!! Quote Link to comment
Lobo Posted April 13, 2013 Author Report Share Posted April 13, 2013 So i have my front oil seal leaking bad. i know the org part number is 13042-3000 for the felt seal. witch i can't find. I came up with another part number to and i was curious if any one knows if it will work 13042-B3000 Quote Link to comment
Lobo Posted April 20, 2013 Author Report Share Posted April 20, 2013 So i know the timing chain cover off a j15 will work on a j13 but what about a j16 motor will the timing chain cover work off of that one to for the j13 does anyone have the part numbers for the j15 and j16 Quote Link to comment
