My new 720 4x4 (clean)
Toon
Just bought my first Nissan and I got to say that I love it!
Although it does need some repairs and adjusting, so I will stay posted.
I'm new to the site and I will need some help along the way.
I Bought this from a kid my age for $2,500, came with new tires and rims with 4 spare mudders.
Dual 12" Renegade subs with 900 watt amp and pioneer deck. 4x4 works great.
This truck is my favorite vehicle so far and tend to keep it for awhile.
Need help with a couple things...
The truck runs on a high idle (3000) when starting up. Vacuum leak?
Clutch needs to be adjusted, stalls out when shifting into neutral
and stalls when the clutch is pushed in all the way.
Many thanks, Toon. :thumbup:
  • Replies 6
Clutch master and/or slave. Check to make sure they aren't leaking. Mine was doing that until I replaced the slave cylinder.
Mine has the high idle issue as well. I haven't traced it down yet. I believe there is a high idle adjustment screw some where on the carb. I would check the hoses as well while you are looking it over.
  • 4 weeks later...
Looks like either an '85 or '86. You should put that in your profile so people don't have to ask. Sometimes helps to know the year when diagnosing a problem.
This is normal when starting a cold motor that has a carb. If all the time it could be...
Choke stuck on... causes fast idle circuit to be on also.
Throttle cable adjusted too tight... needs a little slack
Secondary throttle plate stuck slightly open or stuck.
Idle cut solenoid not working and PO turned the idle up.
Again helps to know what year. There is a neutral transmission and a clutch switch so maybe something there not right.
Take a picture of the carb with the air filter off too.
I found out the problem, I needed a battery and alternator.
Changed parts for a Duralast Gold battery and a new Alternator
Sam and I decided to rip out the interior for shorts..
Left over wires, a broken viper alarm system.... 20130310_142032_zpsc84e4219.jpg
.Cleaned the floor, carpets, dash parts.
will post finished pics later.
