Dguy210 Posted February 13, 2013 Report Share Posted February 13, 2013 Offenhauser Dual Port intake Manifold #6002 Picked this up a while back and realized I will never get around to using it. Located in Sacramento California. Shipping should be in the ~12-15 dollar range depending on zip. Bolts directly to a Weber 32/36. $200 obo or will trade for a flipped 510 crossmember for a KA swap. Link to comment
Bullet_side Posted February 14, 2013 Report Share Posted February 14, 2013 Is this for an L-20B? Link to comment
Just Joel Posted February 14, 2013 Report Share Posted February 14, 2013 Yes, so long as you run a Weber 32/36 ;) Link to comment
CorAce Posted February 14, 2013 Report Share Posted February 14, 2013 Whats with the bars in the intake runners? Link to comment
laotsu Posted February 14, 2013 Report Share Posted February 14, 2013 Whats with the bars in the intake runners? Offenhauser Dual Port intake manifolds feature completely separate runner systems for the primaries and secondaries. At low-load, the primaries feed the fuel-air charge through the smaller bottom passages at near sonic speed, improving power and efficiency. When the secondaries open, their charge goes through the bigger, cooler upper passages. Then, in turn, it is rammed into the cylinders when it encounters the high-velocity mix from the primaries. The result is better fuel economy and a 15-30 percent power increase across the whole rpm range. Link to comment
Just Joel Posted February 14, 2013 Report Share Posted February 14, 2013 And also why its designed primarily for a 32/36 Link to comment
Bullet_side Posted February 14, 2013 Report Share Posted February 14, 2013 While doing a little research, it shows that this intake is for a 1600 1968-1974. I'm not sure if it will work on an L-20B. It says to use a 6144 manifold on late 1974 to 1975 and 6178 for 1976-1980 L-20B. Does anyone know why? I'm not sure if it will work properly for an L-20B. Thanks for any help on this matter. :confused: Link to comment
hobbes_the_cat Posted February 14, 2013 Report Share Posted February 14, 2013 The mani ports are matched to the smaller ports of a L16 or L18 head. It will work on an L20b because the L20b has bigger intake ports. I ran this same mani on a head ported to L20b specs and it worked fine. Great actually. Link to comment
Dguy210 Posted February 20, 2013 Author Report Share Posted February 20, 2013 Sold. Mods please lock. Link to comment
