Lownslow757 Posted January 30, 2013 Report Share Posted January 30, 2013 I recently bought an 84 720 z24, did some work to get it driving and it runs pretty good up until 3 grand where it runs rough and then dies out. It was running with bad gas so I drained it all out and put new gas in it but I'm stuck on this problem, need help! Quote Link to comment
KELMO Posted January 30, 2013 Report Share Posted January 30, 2013 Can't help much with the Z24 motor, but, welcome to Ratsun and somebody is gonna as for pics. Almost sounds like an air flow meter issue but 720s didn't really have them....maybe a heated base plate under the carb? Yeah like I said not really a 720 guy, but hang around awhile lotsa smart guys on here. Quote Link to comment
wayno Posted January 30, 2013 Report Share Posted January 30, 2013 Welcome to Ratsun B) Quote Link to comment
Lownslow757 Posted January 30, 2013 Author Report Share Posted January 30, 2013 Ill get some pics posted soon and thanks! Quote Link to comment
JoeCool Posted January 30, 2013 Report Share Posted January 30, 2013 Welcome aboard, Where's the pics? Quote Link to comment
ColtonMelson Posted January 31, 2013 Report Share Posted January 31, 2013 I would say go through all the vac lines first. I put a whole rebuild kit on my carb and still had problems. 2 weeks later i found a broken vac line i had missed. i fix it and bam the problem solved (not to say i have not had other things to worry about and fix) But if its not a vac line you can always do a rebuilt kit and blow the carb out good with compressed air and carb cleaner. Please please use safety glasses, I caught some carb cleaner to the eye and it shut down my whole world for about 20minutes. im sure there are other things to think about, im sure some of the more seasoned datsun guys will chime in. Quote Link to comment
720life Posted April 25, 2013 Report Share Posted April 25, 2013 Just make sure when you are using compressed air to clean that you dont accidentally blow down into the primary jet. Im not sure how the Z-24 carbs are but I was cleaning my 720 carb a few weeks ago and wasnt being careful enough with the air and blew down into the primary, straight down into the float chamber and right up into the accelerator pump, blowing the rubber bushing all apart. And thats why I now have a weber lol And i definitely agree with Colton, USE SAFETY GLASSES! Quote Link to comment
Telkwa Posted April 25, 2013 Report Share Posted April 25, 2013 If it runs OK at idle, and at lower rpm's, but dies at high load/rpm, wouldn't that indicate a fuel flow issue? I'd probly check filters first. There's a filter at or inside the electric fuel pump back at the right rear tire (not sure exactly where) and you may have an inline filter somewhere else. Especially if you had bad gas. Years ago our 720 got some bad gas that had water in it. The float bowl ended up about half full of water. The truck ran erratically, but it got worse when I'd make a hard turn for some reason. A few doses of gas dryer (it's just alcohol) finally cleared it up. Could be float (?) but I'd start with the easy stuff first. Quote Link to comment
