datzenmike Posted February 16, 2013 Report Share Posted February 16, 2013 '86.5 through '89 D-21 Hardbody with Z24i motor. Starters should be the same. My Z24 I bought from a rolled '84, on removal had " '89 Z24i " written on the flex plate, so it had been swapped. Best of all the '89 flexplate was on the '84 automatic so the plates must be the same too. The D-21 automatic appears to be an L4N71B or 4 speed. The 720 was only an L3N71B 3 speed with locking torque converter. Quote Link to comment
oneslick720 Posted February 16, 2013 Report Share Posted February 16, 2013 I found a 92 240 sx with ka and an auto.. With that work? Quote Link to comment
metalmonkey47 Posted February 16, 2013 Report Share Posted February 16, 2013 Holy crap mike, that guide is awesome! Quote Link to comment
Mr.Dean_Yates Posted February 18, 2013 Report Share Posted February 18, 2013 Okay so I got the tranny in and did a little custom work. Getting a drive shaft made tomorrow. 1 price conversion because I hate carrier bearings and such. I love where the new shifter sits. Very comfortable. After I get the drive shaft made and in place I will post lots of pics. Quote Link to comment
oneslick720 Posted February 23, 2013 Report Share Posted February 23, 2013 What about the computer and such Quote Link to comment
datzenmike Posted February 23, 2013 Report Share Posted February 23, 2013 Holy crap mike, that guide is awesome! You mean the one I posted on the other page? Quote Link to comment
Samuel Posted February 23, 2013 Report Share Posted February 23, 2013 Okay so I got the tranny in and did a little custom work. Getting a drive shaft made tomorrow. 1 price conversion because I hate carrier bearings and such. I love where the new shifter sits. Very comfortable. After I get the drive shaft made and in place I will post lots of pics. I've been considering this swap, so when your done, I would love to see some details, aggravations, and what not's. Plus pics of course. How far back did the shifter sit from the original anyways? I remember reading a thread about a 240sx transmission swap once. but couldnt remember where. I'll try to find it. Quote Link to comment
datzenmike Posted February 23, 2013 Report Share Posted February 23, 2013 Well the S13/14 71C is at least several inches longer than the longest 71B so I assume the shifter moved back slightly. Most shifters could afford to move back slightly. Easier to grab. Quote Link to comment
Samuel Posted February 25, 2013 Report Share Posted February 25, 2013 I don't know how similar the two are, but would it be possible to take the gears from the s13/14 71c and pack them in to the 71b? From what I read so far the s13 uses a slighty bigger input bearing than the 720, but for the most part is it possible? I should of searched before posting. -_- http://720world.com/forum/topics/fs5w71-bc-transmission-faq not a step by step but a decent clear answer. Quote Link to comment
datzenmike Posted February 25, 2013 Report Share Posted February 25, 2013 ......y...e...sssss...... perhaps just the gears. The S13/14 mainshaft is too long to fit a 71B case. You will have to mill the front of the 71B case for clearance. It's the front counter bearing that is larger 62mm than the 71B 56mm. Also the 71C 1st/2nd shift rod is lager diameter 16mm than the 71B 14mm. Way easier to swap a 71C in and have a driveshaft shortened. Quote Link to comment
Samuel Posted February 25, 2013 Report Share Posted February 25, 2013 Found my answer, I'm asking because, I could care less about ease. I'm kinda anal and want the benefits of the C, and the correct positions for the B. If you will, I want my damn cake and eat it too. Quote Link to comment
Mr.Dean_Yates Posted February 28, 2013 Report Share Posted February 28, 2013 Personally...it depends on what you wanna do with the truck...I'm going turbo, my tranny has a short throw, its a short 2 piece "dogleg" as well. It sits right at my thigh. Its supper comfortable and I know for a fact I'll be able to slamin gears a hell of a lot easier that way...I'm also contemplating doing an e brake relocation if I have enough clearance. Gonna go back to the jy I got my drive shaft from and take the handle out of it and see what I can do about fabbing it into the truck Quote Link to comment
