ssnapz Posted January 2, 2013 Report Share Posted January 2, 2013 so im doing a 3 link on my 720, and on a budget of coarse. i cant afford coilovers so i grabbed a bucket of honda coilovers from my buddy. found me a pair of shocks from a 1960 corvette at autozone for $20 a piece then went to work. Quote Link to comment
ssnapz Posted January 2, 2013 Author Report Share Posted January 2, 2013 the steel is 2 pieces of exhaust tubing, 1 3/4 x 7 1/2 and 2 1/2 x 3. the disc and ring are 3/16 plate cut out on a plasma table. all are scrap parts except for the shocks, so i got away with building them for $40. next step is pull my bed so i can build the 3 link Quote Link to comment
Farmer Joe Posted January 2, 2013 Report Share Posted January 2, 2013 its a good idea, but those rubber isolators are not meant to hold the weight of a vehicle. im subscribed to the thread tho, cuz i like to do things on the cheap too. id like to see how it turns out. Quote Link to comment
ssnapz Posted January 2, 2013 Author Report Share Posted January 2, 2013 if i can find them i will use the adapters that covert the studs to eyes. maybe find hiems and thread them on the studs Quote Link to comment
jrock4224 Posted January 24, 2013 Report Share Posted January 24, 2013 yeah u need to swap to a thru eye style shock ......the shaft mounts wont fair well.....by three link do u mean a wish bone style.....and i have never seen a adapter to swap nor do i thin k that will fix the issue....adapter is car talk for future failure look here.... Quote Link to comment
jrock4224 Posted January 24, 2013 Report Share Posted January 24, 2013 yeah i just figure being a mini truck he was thinking of a wishbone link set up ...which allows the stock tank location to be used..cause what u pictured is more of a two link with a panhard bar....just like what im referring to is more of a wish bone then a 3 link ... but in the mini truck world its called a three link more than a wish bone... Quote Link to comment
ssnapz Posted January 31, 2013 Author Report Share Posted January 31, 2013 by 3 link i mean 2 lower links one upper link centered and a pan hard. simple cheap and efective. lower links will mount to stock leaf perches and brackets welded.to rear end, upper will be longer for antisquat and mounted to a crossmember made for the link and welded.rear end mount. pan hard will go from frame rail to oppisite side of axle. planing the swap for a couple of weeks from now(building my golf cart first). i will make a thread with lots of pics. Quote Link to comment
I'm BLUE Posted January 31, 2013 Report Share Posted January 31, 2013 did you use exhaust pipe ? Quote Link to comment
ssnapz Posted January 31, 2013 Author Report Share Posted January 31, 2013 yes i did. Quote Link to comment
