agent281 Posted December 26, 2012 Report Share Posted December 26, 2012 Ok...My '77 b210 has been acting up and I have no idea what it could possibly be. It runs like its running out of gas, or the timing is off, or its missing a spark or something. It will have random moments of running just fine, and it usually idles fine, but the rest of the time it runs so poorly its undriveable. I've checked the plugs, the wires are all sparking, the timing is correct, the points are good and gapped right, it has a newer weber that hasnt given me any trouble, i even adjusted the valves, changed the fuel filter, and triple checked for any vacuum leaks. The coil is fairly new and in working order, and the ignition switch is fairly new as well. I checked the grounds, and the wire going to the distributor, and made sure the choke wasnt stuck. I am completely out of ideas, I really hope someone here can help me. Thanks!! Quote Link to comment
Skib Posted December 26, 2012 Report Share Posted December 26, 2012 there is gas in it right? lol sounds like maybe something plugging up your main jet? Quote Link to comment
datzenmike Posted December 26, 2012 Report Share Posted December 26, 2012 You really should complete your profile with a rough location. When does it do this? When cold, when warmed up? If you shut it off and let sit for 5 min, does the problem go away but come back within a few blocks? Is it cold and damp where you are? Quote Link to comment
wayno Posted December 26, 2012 Report Share Posted December 26, 2012 This is the fuel input area for the weber carb, and this is the bottom side of that area, see the big nut bottom center, take that out and check the screen/filter, I have had that one plug up solid, generally the symptoms of that are you are fine at lower RPMs, but on the hiway(higher RPMs), the engine just won't run. Quote Link to comment
ggzilla Posted December 26, 2012 Report Share Posted December 26, 2012 The B210 carburetor looks very different than that Weber carburetor. These symptoms are usually caused by a little bit of crud in the carburetor fuel bowl: * It runs like its running out of gas * It will have random moments of running just fine, and it usually idles fine, but the rest of the time it runs so poorly its undriveable To solve this problem, drain the fuel bowl: 1. Change the fuel filter 2. Clean the carburetor inline filter (if equipped) 3. With engine cold, remove the main jet plugs from the bottom of the carburetor 4. Refasten the main jet plugs This may need to be repeated two or three times if the problem does not totally clear up. Alternatively you can remove the carburetor and clean the fuel bowl out, backflushing the main jets and rinsing the fuel bowl clean. Quote Link to comment
Skib Posted December 26, 2012 Report Share Posted December 26, 2012 The B210 carburetor looks very different than that Weber carburetor. psssst.... it has a newer weber Quote Link to comment
ggzilla Posted December 26, 2012 Report Share Posted December 26, 2012 Ah, OK. Weber is a bit harder to work on, but the same applies. Clean the inline inlet filter per wayneo's photos Clean the fuel bowl by removing carb, remove the carb-top and tip it over, let fuel drain out. Rinse with fresh gasoline. Unfortunately it doesn't have a fuel bowl drain. Quote Link to comment
Nicholas7620 Posted December 28, 2012 Report Share Posted December 28, 2012 I'm having similar problem. Great post GGZ aka Road Warrior, big help. I just checked for an inline fuel filter. I couldn't tell without doing some dismantling. I'm going to my own thread and post OIC's. Quote Link to comment
