drop spindles for 620
DATSUN671
  • Replies 10
DATSUN671 said
yes i do have a 620 with disc brakes and ball joints...
so would i will be able to use the 720 or HB drop spindle...
what parts do i need to run the 720 or HB drop spindle....
but why can't i use 14in rims...
thanks for the help
The reason you likely can't use 14 inch wheels anymore with drop spindles is that the lower balljoint is moved closer to the inside of the rim, it will likely hit the rim, making it impossible to mount the rim on the hub, drop spindles have consequences.
The drop spindle will just mount to your balljoints, but you will have to convert over to the late 720/hardbody vented rotors/calipers I beleave, as that are what the drop spindles on ebay are for, late 720/hardbody trucks.
