Relocated gas tank?
socaldatsun
  • Replies 32
Been looking at this as well. Between the rear 2 frame crossmembers front to back is roughly 18". Frame rail side to side is roughly 36". Now.... the problem is if you go flush to the bottom of the bed, 10 inches will bring you almost to the bottom of the license plate.
Lotta gas man. my 86 720 is 10 gallon. Problem with those big tanks is sometimes they get deeper, which may really kill your departure angle or entry angle going in/ out drive ways etc. My advise get it up as high as you can, before it crashes into the bed floor and get it as close to the diff as possible. or look into buying or getting a fuel cell made with a angle on the bottom.
