Rustina 510 Posted November 25, 2012 Author Report Share Posted November 25, 2012 Yeah it's going to take some major work but I'm pretty sure with ratsun behind me I can get it all done fairly quickly Quote Link to comment
Laecaon Posted November 25, 2012 Report Share Posted November 25, 2012 Yeah it's going to take some major work but I'm pretty sure with ratsun behind me I can get it all done fairly quickly As quick as your wallet allows. 1 Quote Link to comment
Rustina 510 Posted November 25, 2012 Author Report Share Posted November 25, 2012 Yeah good thing I got a big raise, that's when I decided to pull the trigger on this project Quote Link to comment
Rustina 510 Posted November 25, 2012 Author Report Share Posted November 25, 2012 I'm hoping to drive this motor to canby Quote Link to comment
Rustina 510 Posted November 26, 2012 Author Report Share Posted November 26, 2012 Little update. I have everything off but rod #2 won't let go of the crank and is really pinched on their. And the crank looks pretty damaged, looks like I might need to get a new one, I was able to clear the rod cap that was in 3 pieces Hopefully I can break it lose tomorrow Quote Link to comment
Rustina 510 Posted November 27, 2012 Author Report Share Posted November 27, 2012 We got the crank out, doesn't look to good, block looks pretty good though so I guess that's something positive. I think I might need a new crank, does anybody do a regrind on cranks? Is a de crank the same as a single cam crank Pics The rod of death Quote Link to comment
Rustina 510 Posted November 27, 2012 Author Report Share Posted November 27, 2012 Quote Link to comment
DRIVEN Posted November 27, 2012 Report Share Posted November 27, 2012 Crankshaft City 1109 SE Brooklyn Street Portland, OR 97202 (503) 231-1936 It's right next to Central Cylinder Head. Quote Link to comment
ssnapz Posted November 27, 2012 Report Share Posted November 27, 2012 crower makes a 2.6 stroker kit, comes with crank rods and pistons. i think its like $2600 though if its in your budget that would be fun Quote Link to comment
Draker Posted November 27, 2012 Report Share Posted November 27, 2012 Store your crank either in the block or standing up on the flywheel end. Any other way will result in further damage to the crank. Quote Link to comment
alabama_lowlife Posted November 27, 2012 Report Share Posted November 27, 2012 Store your crank either in the block or standing up on the flywheel end. Any other way will result in further damage to the crank. Why exactly is that? Out of curiosity. Quote Link to comment
Draker Posted November 27, 2012 Report Share Posted November 27, 2012 Because they don't sit flat if you lay them down. It's even worse if you store them horizontally supported on the ends. They are very heavy will deflect on them selves from their own weight. Small amounts of deflection can be machined out.. but too much and you've got scrap metal. Quote Link to comment
Rustina 510 Posted November 27, 2012 Author Report Share Posted November 27, 2012 crower makes a 2.6 stroker kit, comes with crank rods and pistons. i think its like $2600 though if its in your budget that would be fun Would that make the motor a ka26e-r? Quote Link to comment
Rustina 510 Posted November 27, 2012 Author Report Share Posted November 27, 2012 All they have is the dual cam stroker kit so again. Is it the same block and crank for the dual and single cam Ka? Quote Link to comment
Rustina 510 Posted November 27, 2012 Author Report Share Posted November 27, 2012 So the dual cam is different from the single cam. The snout is longer on the single cam because the distributor runs differently from the 2. So the stroker idea doesn't seem to be a viable option sense crower stroker kit is set for the dual cam engine Quote Link to comment
Rustina 510 Posted November 28, 2012 Author Report Share Posted November 28, 2012 Crankshaft City 1109 SE Brooklyn Street Portland, OR 97202 (503) 231-1936 It's right next to Central Cylinder Head. Thx for the tip, I called and they said a true regrind 100$ Hot tank, 100$ including some additional work to the oil and water passages Port & polish, 80$ a hour :( So two of three isn't bad Quote Link to comment
Laecaon Posted November 28, 2012 Report Share Posted November 28, 2012 Regrind crank, means undersizing of the connecting rod/main bearings. Its opposite of boring a motor. Quote Link to comment
Rustina 510 Posted November 28, 2012 Author Report Share Posted November 28, 2012 Actually what I have read a little about and was told by previously said company, they can add material "metal" back to the crank and do what they called and I repeated as a true regrind. Dude was really cool and very happy to be helping with a Datsun project, can't remember his name but he was very cool to talk to Quote Link to comment
Laecaon Posted November 28, 2012 Report Share Posted November 28, 2012 Der, I missed the word true. Quote Link to comment
DAT510 Posted November 28, 2012 Report Share Posted November 28, 2012 I'm mos def following this thread :devil: Quote Link to comment
Draker Posted November 28, 2012 Report Share Posted November 28, 2012 You can port it yourself. Quote Link to comment
Rustina 510 Posted November 28, 2012 Author Report Share Posted November 28, 2012 You can port it yourself. Looks like I'll have to, I'm not paying 80$ a hour Quote Link to comment
Rustina 510 Posted November 28, 2012 Author Report Share Posted November 28, 2012 I've been looking fr a stroker crank for the single cam, I'm really interested in a ka26e-r, only a few have ever been built as far as I can find... Quote Link to comment
Draker Posted November 28, 2012 Report Share Posted November 28, 2012 I wouldn't waste your time on it. For that kind of cash you can do a turbo SR. Quote Link to comment
Rustina 510 Posted November 28, 2012 Author Report Share Posted November 28, 2012 But that's just it draker. I don't want a sr, I want a single slammer Ka with some major balls Quote Link to comment
